Filling Coolant
asoupley
Any trick on filling the coolant? I followed the manual (I think), but after running the engine for a while, when I squeeze the upper radiator hose, it does not feel like the system is full... am I just paranoid? Any way to make sure?
Thanks
Tony
Bugeye58
Tony, a sure fire way to do it is to pull the thermostat housing and fill the block from there. Run the engine with the heater valve open, (after reinstalling the t-stat housing, of course) and top up the expansion tank as necessary. This has always worked for me when filling the system from dry.
Jeff
jlaird
Why shoot, I just fill it up then do it again in 10 min or so. Never a problem.
Bugeye58
Jack, the cross flow systems can be a bit of a fiddle at times.
I've always done the down flow systems as you do, and have never had any difficulty.
Jeff
jlaird
Woops again, did not realise cross flow.
Oh well if the brits at the factory did it it must be easy. hehe.
Billm
I have always drilled a 1/8" hole in the flange of any thermostat that I put in an LBC. This allows the air out on filling and if the thermostat fails then at least there is some water flowing. Doesn't hurt warm-up enough to really matter. There used to be thermostats that sort-of did this and had a little plastic piece in the hole.
Bill
kcbugeye1275
The 1/8" hole is a good trick I just recently came across. However, I do four holes.
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T filling/flushing steering rack Spridgets 7
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
R Filling overdrive oil on BJ-7 Austin Healey 5
BOBBYR Filling my O/D transmission Austin Healey 8
CCURTISS TR2/3/3A Filling TR3 Steering Box Triumph 10
B Filling SU Dampers? Spridgets 20
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
L Filling shocks MG 16
T Filling rear Bugeye shocks - any tips? Spridgets 7
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
R question on filling rear shock....[armstrong] MG 3
Obtong Filling Steering Rack/Boots MG 6
K Filling a grease gun Restoration & Tools 9
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
