TR2/3/3A Filling TR3 Steering Box
CCURTISS
It the proper place to fill the steering box the plug on top of the box or the hole in the tube (under rubber plug in shaft)? Wondering if the hole in the tube just lets fluid run into the steering box?
Thanks,
Twosheds
The hole in the tube. It's a whole lot easier to reach.
TR3driver
Great Pumpkin - R.I.P
:iagree:But it does take some time for it to run down into the box.
tdskip
Are you using the factory spec oil or a thicker lube like Penrite? The Penright stuff is so thick I think you'll have to add that directly into the filer in the box....
Geo Hahn
I add the Penrite thru the steering column. It is slow so rig the funnel using towels, duct tape or whatever. Pick a hot day.
Have something else to do as you will add--wait--add for awhile. Do it at 10:00 on Saturday morning and listen to Car Talk.
If you need to fill the box from empty then it is probably worthehile removing the d/s horn and getting at the fill plug.
tdskip
Yeh, I had to remove the horn to gain access. You mush be referring to a hot AZ day, since on a warm SoCal day the Penrite is still pretty thick.
Maybe I should let the bottle sit in the sun for a bit first!
CCURTISS
CCURTISS
The 1st time I filled mine (from the steering box plug) it leaked out the nut on the end tube pretty quickly. I tightened up the nut and am going to try again with the standard fluid to see what happens.
Number_6
In Roger Williams book 'How to Restore Triumph TR2, TR3 & TR3A' He recommends that that you warm the oil in hot water for a while before using it. When the oil gets warm it will thin out and then thicken back up again after it cools.
TR3driver
Penrite ! No wonder you guys think sidescreen cars steer hard !
I use 75W90 full synthetic gear oil, which is thinner than 20W50 motor oil at room temperature.
Twosheds
There is a large oil puddle under my steering unit.
Is Penrite used full strength or mixed with the existing oil in the steering unit?
tdskip
I've been told to us it full strength.
Randall - my box holds oil just slightly better than a sieve holds water. Hence the goop, aka Penrite.
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T filling/flushing steering rack Spridgets 7
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
R Filling overdrive oil on BJ-7 Austin Healey 5
BOBBYR Filling my O/D transmission Austin Healey 8
B Filling SU Dampers? Spridgets 20
A Filling Coolant Spridgets 6
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
L Filling shocks MG 16
T Filling rear Bugeye shocks - any tips? Spridgets 7
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
R question on filling rear shock....[armstrong] MG 3
Obtong Filling Steering Rack/Boots MG 6
K Filling a grease gun Restoration & Tools 9
