scott_74
Member
I had posted back in April about my 1275 going through short, intermittent spits of power loss. Having replaced the condenser a few days prior, I ended up swapping in a new one and it fixed the problem. That is, until recently, when similar symptoms arose...to a much lesser extent.
So again, I swapped in a new condenser. And it runs great now.
I'm getting tired of replacing these things, and I'm considering getting an electronic ignition. Is this a smart move? If so, which one do you all recommend? I understand some replace the whole dizzy whereas others utilize your existing one. What are the benefits of each?
Sarastro...at your request, I'm planning on mailing you one of my bad condensers on Monday. I'd be interested to see what you find.
Thanks all.
Scott
Thanks all.
Scott
