Hi Tahoe,
To answer your question about radio noise; Yes, there is a big
difference in radio noise with the types of wire used;
Maximum radio noise= Standard Metal wires, (stranded or solid core).
... The standard metal wires act like little radio transmitter antennas. The higher voltage coil you have equates to a stronger " transmission " from the wires.
... When standard metal wires are used, there is no limitation
on the current flow through the distributor cap, rotor, and ignition wires thus a strong transmission of noise from the ignition wires that reaches your radio, ( am, fm, and it is strong enough to make noise when playing CDs or MP3 players).
... Both carbon core ignition wires and wound metal core wires
inhibit maximum current flow and thus eliminate electrical noise transmission from your ignition system.
Because of the greater current flow through standard core wires, the POTENTIAL for damaging an electronic ignition sensor is greater since there is more current flowing through the coil than if carbon or wound wire ( looks like a long spring inside of the insulation if you could see it ). That doesn't mean using solid wires will cause the petronix failure, but if a weakness in the hall effect transistor develops over time, then the big current is available to " finish it off in a hurry ". This won't happen as quickly with carbon or wound wire ignition wires.
.... That's probably more than you wanted to know. I apologize.
... My recommendation is Magnacore ignition wires. They sell three different sets for our 6 cylinder Healeys. One set is black colored and will install into the standard side entry distributor cap ( 7 mm ). I use the red 8mm wires into a top entry distributor cap.
This is a lot like recommending the best motor oil. I am certain there will be many other opinions about this. Carbon wires don't last as long as these type of wires but will also work well until the carbon starts to break down from the heat inside of the engine compartment. And Dave has correctly pointed out in the past that if you simply replace the wire that goes from the coil to the distbutor cap with a type that limits current, then you can still use the solid core wires from the distributor cap to each spark plug as the coil wire will limit the current flow to each spark plug.
Others opinions will vary !
Ed
