"Bumblebee" spark plug wires.......
karls59tr
Bronze
These look authentic but tend to get brittle over time. Anyone using a differnt brand of plug wires that are better quality or more high performance?
G
Re: "Bumblebee" spark plug wires.......
A friend brings his Bumblebee wires to show and puts them on when the car is being shown. Uses better wires to go to and fro.
PeterK
You can still get them new, nice solid copper wires. But are not compat with Pertronix or other electronic dizzys.
Geo Hahn
I use the copper wires as I think you get better contact when using the TR3-TR4 dizzy caps that have a pointy screw to penetrate the wire.
I got a universal 8-cylinder set from a local CarQuest for short money. There was enough wire in there to make 4 or 5 sets of 4-cyl TR wires.
I also use those snap-on 'Champion' caps on the plugs. They screw into the ends of the wire for a solid connection and attach to the plug with a definite snap so you know you have it secure -- yet very easy to unsnap when need be.
K
karls59tr
Bronze
Hi Peter Did you say the bumblebee wires are not compatible with Pertronix? Why is that? That's what I'm running now and I'm in the process of tracking down missing at speed by changing SU needles and recurving the dizzy. Are the bumble wires a contibuting factor to my problem?
kodanja
can someone post a pic of bumblebee wire....?
PeterK
Karl, I don't have the specifics but ~solid core wires emit some kind of interference that affects the electronic points conversions~.
Probably have it all wrong but ~if you have a Crane or Pertronix points conversion AND are using solid core copper-type wires~, swap out the wires to see if your problem goes away.
We run points with orange Champion solid cores on the 3A. I have a Pertronix conversion for it but haven't had to reason to install it yet.
From Magnecor web-site: https://www.magnecor.com/magnecor1/truth.htm
rufus1120
Hi
I have been using bumblebee wires and pertronix points for over four years and have not had any problems. As I show my TR4 in concourse the judges donot like the Bumblebee wires. I am going to change them out. I have also heard they do not work well with pertronix,
Brosky
Hey Rufus, how about a couple of pictures of your car? I love TR4's!!
M Bumblebee ignition wires Triumph 23
nathandarby67 Bumblebee Plug Wires MG 29
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
S Wedge Need help with TR8 no spark Triumph 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
B TR6 Spark plug gap Triumph 5
