Maybe antifreeze, but I don't know.
Been there, burned that -- (green) antifreeze stains the porcelain green and leaves a greenish-white crusty residue.
In my experience, wet plug(s) are simply a sign that the piston was on the intake or compression stroke when the engine was shut off. It's the fuel that would have burned on the next power stroke.
I *think* that carbon on one plug could be related to the loss of compression in that cylinder. Compression makes the fuel burn more efficiently (more completely / hotter / cleaner). Low compression therefore could (I think) leave an abnormal amount of carbon on the plug. If I'm correct, then it's just another symptom and not necessarily an answer.
Or, as Bob suggested, it could be oil in the cylinder(s). Oil doesn't burn as cleanly as gasoline does, so it leaves a mess behind. OTOH, oil burning *often* leaves the plug looking oily, like you used the spark plug for a drain plug.
Also, let's not forget the lesson from all of our medical drama shows: Two symptoms don't necessarily HAVE to be related. There could be 2 diseases happening at the same time. One fouled plug could have been a result of the low compression, but the other might have been misfiring from an ignition issue. Your engine may have been running on 3 for a while, but it wasn't until the ignition issue showed up that it became really noticeable.
Or... one carb has been running rich and was beginning to foul the plugs on 2 neighboring cylinders; then a bit of carbon broke off of one plug and lodged itself on the exhaust valve seat, ruining the seal and losing compression? (Maybe I should stick to writing fiction.)
