I installed a set of BPR6HS plugs (used to be BPR"5"HS that was recommended?) and now the car seems to idle and run a bit rougher than when I had the older BPR5HS plugs in. I had the old plugs gapped at .032 and it seemed to run smooth there. I'm going to put the older plugs back in to see if that makes a difference. If the gap is the issue the "6" NGK's have a recommended gap of .025.
What else should I check in regard to ignition? When I had the old plugs in they ran well with the newly installed points and condensor.
