Copper core plug wires
Dennis P
Does anyone know who sells the origional type ,copper core plug wires that MGs used to come with? Have not seen any in the various catalogues. I recall reading they are superior conductors and last longer than the new type wires.
aeronca65t
I bought solid core (for my time trials racer) from my local Harley shop, but I've also seen it at speed shops (you'll probably have to order it).
My car has points at the moment, but I'm considering the Hitachi distributor conversion I've seen mentioned somewhere on this forum...I'm not sure if the extra electrical "noise" will create problems for the electronics, so I may end up switching back to suppression wires
You can also get "raw" solid-core plug wire and connectors from "aircraftspruce"
go here and click on "engine parts" and then "spark plugs".
https://www.aircraftspruce.com/catmain.php?dest=cathome.html
[ 02-13-2003: Message edited by: aeronca65t ]</p>
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
TomMull Copper nickel lines again Restoration & Tools 0
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
glemon General Tech Nickel Copper Brake Lines Triumph 10
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
NutmegCT T-Series the copper pipe? MG 19
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
M brake pipe copper straps Spridgets 19
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
Z Copper spray and coated head gaskets? Triumph 0
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
C Testing heater core Austin Healey 9
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
I Weeping Core Plugs Austin Healey 6
T TR4/4A Core Plug - Cam Rear change Triumph 7
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
