I am currently making preparations for engine assembly within the next 3-4 weeks, and am trying to decide between steel and copper Fo8 gaskets. I understand the corrosion aspect, but the copper gaskets I have are 0.003" thicker than the steel ones (0.018" compared to 0.015"). Are these equivalent thicknesses due to copper being a softer metal that will compress more once the head is properly torqued? If not, I believe the extra 3-mils will force me to take down the liners some, and I'm not sure going with copper is worth the extra step. Also, I assume that two sets of Fo8 gaskets are required - one for checking protrusion after torquing and removing the head, and the second for final assembly. Is this correct?
Joel
Joel
