Correct Colors for engine & Head?
Number_6
I’m quite a way from it, but what is the correct colors for the engine block and head for a 61 TR3A? I’m guessing that the block should be black. What color should the Head be? I’ve seen it a painted dark blue in some places and in other times it’s painted black. Anyone now what is correct?
Geo Hahn
The TRA judging guide says all heads (and blocks) are painted black.
If oyu do not have this guide I can send you a PDF copy. A very interesting and useful document even if you are not trying for concours correct.
Number_6
Number_6
Hi Geo, Thanks, PM sent. That will be very usefull going forward as I get more work done on the car. I'm not really doing a concours car but where ever possible I like to keep things as original as possible.
Brosky
Ya know, there's a reason for the multi-color selection of engine paints!!
Just kidding, but with the color of the body on yours, the engine would look really good in Dupli-Color 1200 Degree Red Ceramic.
Clear coat will be optional.
Number_6
Number_6
Red would look good but after all the red Erik used to painting your engine I'm not sure he has any left! :laugh:
martx-5
Yeah, basic black. That works for me. I even painted the the whole body black. Anytime something needs paint, it's real easy. Frame, engine, body...everything is black...except the interior, I'm doing that RED. :laugh:
G
My favorite color on a TR3. When I had mine (many moons ago) it was the same, Black outside and Red inside. I miss it.
Brosky
If it wouldn't have cost me a home, the TR6 would be black. She loves her black Taurus, but no go on a black TR6.
For my dream car, all black TR4 with no bumpers, worked over engine and suspension sporting silver alloy wheels, with wide tires.
Someday I'll build one and park it next to the banana.
That engine will be red though!
nathandarby67 Correct Midget Engine Colors? Spridgets 11
Lbp TR2/3/3A Correct Colors for Hoodstick and Sidescreen Mounts? Triumph 12
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
