So - it is time to reinstall front suspension hub which requires putting the Pivot Bolt (#92 from below) through the newly installed nylon bearing (#94) and the trunnion. Everything was going well but when I did a test fitting the wishbone arms are not perfectly lined up, there is about a 1/16 offset that is preventing the pivot bolt from sliding through.
I have the lower A-arms and lower pan installed along with the spring (with spring compressor) under compression.
Ideas? Normal to have this happen (OK to lie to me and say "heck yes" or similar)?
