Have decided to install the stock rubber bushings. Have the following questions:
--Using the threaded-rod method, is it possible to press the bushings out and in with the trailing arm in place on the car?
--Failing that, is it possible to detach the brake plate and lines from the swing arm while leaving the e-brake and brake pipe still attached to the plate, moving the brake plate off to the side while dropping the trailing arm off the car?
