TR2/3/3A tr3 radiator over flow hose
sp53
Hi all I posted a picture of what I believe to be what an original over flow tube would like on a tr3 radiator. Please correct me if I am wrong because I am only guessing.
Steve
mrv8q
No pix attached...
bgbassplyr
By George, King that is, I believe you've got it!
jdubois
You mean the plastic tie-wraps haphazardly holding mine to the fender weren't original? :shocked:
TR3driver
Great Pumpkin - R.I.P
I don't recall seeing the clip to the radiator brace before ... are you guys sure that's correct ? I've just got the clip to the inner fender (not that it proves anything).
Don Elliott
sp53 - The photo you show with the clamp at the top bolt holding the rad to the threaded rod is correct to hold the hose. My 1958 TR3A also came with a small circular clamp about 4" below that one where the two tabs on the clamp are inserted into a hole in the side frame of the radiator. From there, it just hangs down to just below the main chassis frame where it will expel any water or antifreeze mix all over the bottom of the RHS of your frame and floor-panels.
But that should never happen as you will never have an overheat problem unless you blow a head gasket climbing a long mountain road where you get stuck behind a bunch of slow-poke tourists in traffic.
The lower clamp 4" down is somewhat like the photo attached but the inverted "V" should be circular.
I seem to remember having a second one of these circular clamps many years ago to secure the hose further down, but I can't find where it would have been. maybe it was inserted into a hole on the inside of the main chassis frame. I'll have to check this out. I had it all apart this past weekend and just put the hose clamps back into place for my overflow hose on Sunday. I don't have any other holes in the side frame of my radiator to insert a lower circular clamp so maybe it is in the frame.
S
sp53
Hi all and thanks for your comments. I put the clip in the inner fender well hole because the other side did not have a hole there. I think I remember TexN saying he found a clip in that area. I will be interested in what Don finds out. Oh Yes, I got the radiator and the little clip at the top From Andy M. and the plastic fan from Mickey. That is what makes this forum so cool.
Steve
S
sp53
this is an old post, but the clip for the overflow hose on the radiator is the same as a fuel line hose on a tr3a and tr3.
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
K For Sale TR3 Radiator Guard Triumph Classifieds 0
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
B TR2/3/3A TR3 radiator removal Triumph 9
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
G TR2/3/3A 7 LB Radiator Cap in TR3 Triumph 4
T TR2/3/3A Radiator mounting bolts on TR3 Triumph 16
K TR2/3/3A TR3 radiator L bracket attachment to Rad? Triumph 2
Tinkerman TR2/3/3A TR3 Radiator Drain Tap Triumph 2
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
CJD TR2/3/3A TR3. Radiator Cap Triumph 8
RedTR3 TR2/3/3A TR3 Radiator Triumph 11
B TR2/3/3A 57 TR3 radiator color Triumph 5
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
TRclassic3 TR2/3/3A TR3 Replacement Radiator Triumph 12
J TR2/3/3A TR3 Radiator Rehab Triumph 9
S TR2/3/3A tr3 radiator Triumph 14
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
E TR2/3/3A TR3 radiator Triumph 0
H TR2/3/3A TR3 Radiator Damage Triumph 7
prb51 TR2/3/3A 4lb. TR3 Radiator Cap Triumph 7
martx-5 TR2/3/3A TR3 Radiator Duct Triumph 3
martx-5 TR2/3/3A TR3 Radiator Mounting Triumph 10
T TR4/4A TR3 vs TR4 Radiator Triumph 2
NickMorgan TR2/3/3A TR3 radiator Triumph 19
C TR2/3/3A TR3 Radiator question Triumph 2
startech47 TR2/3/3A tr3 radiator cap Triumph 11
