TR2/3/3A 57 TR3 radiator color
Mickey Richaud
Piggott's book, <span style="font-style: italic"> Original Triumph TR3 </span> lists engine colors simply as black. Pictures of a "concours" engine shows gloss.
Mickey
TR3driver
Great Pumpkin - R.I.P
I believe it's actually a special "radiator paint", but I don't know what's special about it. Dries thin, perhaps.
Andrew Mace
:iagree: Not a plug (as I've never used it), but Eastwood has three different radiator paints; it does say on their site: <span style="font-style: italic">Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. </span>
mdedon
I've used both versions of Eastwood's Radiator Black. The green can has what I would call a 50-60% gloss to it. The orange can is closer to a "standard" satin. I'm using Rust-O-Leum's off the shelf spray gloss and satin as a comparison.
It actually seems to work fine and doesn't require any primer buildup and holds up under use. At least my experience.
6TTR3A
I painted my tanks Hunter Green, My signature colour! I did use Eastwood's orange can on the core. Seems to be OK, no peeling or flaking from what I can tell.
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
K For Sale TR3 Radiator Guard Triumph Classifieds 0
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
B TR2/3/3A TR3 radiator removal Triumph 9
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
G TR2/3/3A 7 LB Radiator Cap in TR3 Triumph 4
T TR2/3/3A Radiator mounting bolts on TR3 Triumph 16
K TR2/3/3A TR3 radiator L bracket attachment to Rad? Triumph 2
Tinkerman TR2/3/3A TR3 Radiator Drain Tap Triumph 2
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
CJD TR2/3/3A TR3. Radiator Cap Triumph 8
RedTR3 TR2/3/3A TR3 Radiator Triumph 11
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
TRclassic3 TR2/3/3A TR3 Replacement Radiator Triumph 12
S TR2/3/3A tr3 radiator over flow hose Triumph 8
J TR2/3/3A TR3 Radiator Rehab Triumph 9
S TR2/3/3A tr3 radiator Triumph 14
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
E TR2/3/3A TR3 radiator Triumph 0
H TR2/3/3A TR3 Radiator Damage Triumph 7
prb51 TR2/3/3A 4lb. TR3 Radiator Cap Triumph 7
martx-5 TR2/3/3A TR3 Radiator Duct Triumph 3
martx-5 TR2/3/3A TR3 Radiator Mounting Triumph 10
T TR4/4A TR3 vs TR4 Radiator Triumph 2
NickMorgan TR2/3/3A TR3 radiator Triumph 19
C TR2/3/3A TR3 Radiator question Triumph 2
startech47 TR2/3/3A tr3 radiator cap Triumph 11
