TR2/3/3A TR3 radiator L bracket attachment to Rad?
karls59tr
Bronze
This bracket has come off the rad. It is the L shaped part that is held to the radiator support rod by a bolt. I believe the upper part of the rad is copper so how is this bracket attached to the rad? Soldered? Some other method?
TR3driver
Great Pumpkin - R.I.P
It's just soldered on. Normally there isn't a lot of force involved, and the soldered area is fairly large, so that is plenty strong. When my 3A got wrecked, it ripped one of the brackets off the inner fender, but didn't bother the radiator at all.
Kind of tricky to resolder that without getting one of the other joints too hot, IMO. If possible, I'd take it to a radiator shop.
BTW, part of the bracket is joined to the radiator frame, which is steel. The other side joins to the brass upper tank.
Geo Hahn
When I had my radiator out this winter I finally had those brackets put on (had been missing as long as I had the car). I had the radiator shop do them at the same time I was getting other work done.
Only took him a minute but (as Randall notes) it can be tricky. This guy has been soldering radiators for 50 years so he instinctively knew how much heat is enough & not too much.
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
K For Sale TR3 Radiator Guard Triumph Classifieds 0
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
J TR2/3/3A radiator shield for between the frame of a TR3?? Triumph 4
B TR2/3/3A TR3 radiator removal Triumph 9
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
G TR2/3/3A 7 LB Radiator Cap in TR3 Triumph 4
T TR2/3/3A Radiator mounting bolts on TR3 Triumph 16
Tinkerman TR2/3/3A TR3 Radiator Drain Tap Triumph 2
RedTR3 TR2/3/3A TR3 Apron Removal/Radiator Replacement Triumph 10
CJD TR2/3/3A TR3. Radiator Cap Triumph 8
RedTR3 TR2/3/3A TR3 Radiator Triumph 11
B TR2/3/3A 57 TR3 radiator color Triumph 5
M TR2/3/3A TR3 Aluminum Radiator [Wizard] Triumph 18
mrv8q TR2/3/3A TR3 Radiator overflow Q Triumph 4
TRclassic3 TR2/3/3A TR3 Replacement Radiator Triumph 12
S TR2/3/3A tr3 radiator over flow hose Triumph 8
J TR2/3/3A TR3 Radiator Rehab Triumph 9
S TR2/3/3A tr3 radiator Triumph 14
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
E TR2/3/3A TR3 radiator Triumph 0
H TR2/3/3A TR3 Radiator Damage Triumph 7
prb51 TR2/3/3A 4lb. TR3 Radiator Cap Triumph 7
martx-5 TR2/3/3A TR3 Radiator Duct Triumph 3
martx-5 TR2/3/3A TR3 Radiator Mounting Triumph 10
T TR4/4A TR3 vs TR4 Radiator Triumph 2
NickMorgan TR2/3/3A TR3 radiator Triumph 19
C TR2/3/3A TR3 Radiator question Triumph 2
startech47 TR2/3/3A tr3 radiator cap Triumph 11
