Ken_McGuire
OK, recently my car has started running HOT. Today it was above 200 and when I stopped for gas, lots of water/anti-freeze blew out of the overflow. It only seems to stay near 185 when I'm moving which leads me to believe that water isn't circulating through the radiator and I'm just getting cooling from air flow while driving So - a few questions.
1. I've read on here about plugging the bypass. I live in Cincinnati - would this be a good troubleshooting tool to see if the problem is in the thermostat?
2. If I want to check (remove) the thermostat, do I need to drain the coolant as stated in the manual? Seems like it should be near the "top" of the system, so I'm not sure how critical draining is. I found the drain plug on the radiator, but the manual mentions one on the block - where is it? Do I need to remove it, too?
3. Any other suggestions?
Thanks,
Ken
Thanks,
Ken
