TR6 Overheating TR6
Webb
I posted about this over the summer and still have not had it fixed. Long and short of it is that the car runs fine, but when started from cold, the temp needle begins to move up normally, the after about 5 or 6 minutes of running it just rockets to red. It's not the gauge or sending unit. It really is overheating. I've replaced the thermostat already to no avail. Obviously the sending unit and gauge are ruled out since it really is overheating. Engine was recently rebuilt and all passages in the engine are clear. Engine compression is fine and it's not blowing any color smoke whatsoever. I took the fan belt off and turned the water pump by hand, and it turned easily, without hanging up. No lateral movement at all, very solid. I could feel a tiny bit of resistance in a certain area, but nothing significant.
I'm beginning to think it HAS to be within the radiator somewhere. Any other guesses?
tdskip
Well with everything else you have done the radiator stands out. Have you flushed / back flushed it?
Is it original?
Mickey Richaud
Air pocket in the system?
Mickey Richaud
Another thought that occurred to me is you may have a hose that's collapsing.
Andrew Mace
:iagree: It would be worth flushing, not only to see what might come out of the radiator but also what might come out of the block, despite the recent rebuild. If that doesn't help, my next step would be to have the radiator boiled out, rodded out, or even recored.
And forgive me, but I'm assuming that when you say it really "is overheating," you're confirming that either by watching the coolant boil out or checking the temperature of said coolant?
TexasKnucklehead
Rockets to red?
Why would the temperature change suddenly increase? My guess is you've got an air pocket in the line. As soon as the thermostat opens, hot air enters, instead of coolant. I used to pull the tr6 onto a set of car ramps when filling the system with coolant. It's hard to get the cap higher than the thermostat. -Either that or find a way to burb it.
DougF
If you have access to an infrared thermometer, take temperature readings at all corners and several places in between on the radiator. You will be able to tell if there are any blockages.
DNK
Take the thermostat out and insert an aspirin in in it to keep it open and reinstal. Turn on the car and fill the rad. until full let it run and top off as needed. The aspirin will dissolve and your good to go.
T
Tinster
This non-mechanic guy would remove the radiator cap,
crank the engine up and then peer into the radiator fill
hole and watch to see if water is really circulating.
The same "know not-alot" guy would also probably
have my infrared pistol in hand and shoot all over
the place looking for hot ot cold spots.
I would do this test with and without a thermostat
in the coolant system.
<span style="color: #000099">Then I'd replace the radiator, replace the
temp sending unit, replace the temp gauge, replace all
hoses, replace the thermostat, replace the water pump,
refurbish the water pump housing, replace the radiator cap
and finally--- install a new fanbelt and rebuild the
front suspension.
My car never overheats anymore.</span>
dale :thumbsup:
TR3driver
Great Pumpkin - R.I.P
FWIW, My Stag has rather similar symptoms; which I've traced to a leaking headgasket (and/or warped head). Doesn't leak enough to affect power or compression readings, but lets combustion gases into the coolant when under power. Under some circumstances, enough gets into the coolant to air lock the water pump, resulting in instant boilover (sometimes I can even see the steam before the gauge hits the red).
I wouldn't think a TR6 would act that way, since the pump is mounted lower; but if all else fails, it might be worth having the radiator tested for combustion gases. Any radiator shop should be able to do the test in just a few minutes, mine charged me $15. Later I bought the tool on ebay, for about twice that.
Also FWIW, an alternative to the aspirin trick is to drill a small hole in the thermostat backing plate, then install the thermostat with the hole at the top. Some thermostats already have the hole, but most do not. It does slow engine warm up slightly, but makes filling the cooling system much easier.
aeronca65t
Make sure your lower rad hose isn't sucking closed when the thermostat opens.
Watch it as the car warms up.
The lower hose should have a spring inside it to prevent collapsing, but some aftermarket units do not (or on old hoses, the spring tears the inner rubber causing a restriction).
2wrench
Give it one aspirin and call Don in the morning.
Seriously, just another thought would be to open your heater control valve to circulate
water/coolant through the heater core to further dispell any ideas of air pockets.
dklawson
I remember that from "The Puzzler" on Car Talk many years ago. At the time I had a Honda with a cooling system bleed nipple. I thought the aspirin trick sounded like an excellent fix for cars w/o the bleed nipple.
Mickey Richaud
Awright, Webb - SHEESH! It's been almost 18 hours! You're running up quite a tab here, with all this expensive consulting work! So, what's the story? :jester:
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
Webb TR6 Overheating TR6 Triumph 6
T TR6 TR6 with overheating problem - what to inspect Triumph 7
R_Lyle TR6 TR6 overheating Triumph 14
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
W TR2/3/3A Overheating Bad Triumph 12
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating 1957 TR-3 Triumph 13
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
P MGB MGB overheating with a squealing noise from the engine MG 11
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
J '65 Sprite Overheating Spridgets 16
