KVH
OK, I give up. I'm pulling the radiator and taking it to the shop. It shouldn't be nearing the red zone at 6:00 in the evening with the sun going down, and then again later at night--95 degrees or not.
It runs great, and strong and quick, but it's too hot.
Each time I shut it down, it gurgles and churns. I posted awhile back that I put in a new 5 vane water pump. It's done no good, and maybe causing trouble. The radiator shop says the pump might be causing more pressure than the cap can take.
Who knows.
Anyway, I suppose it's agreed that in the evening, when the day is done (Led Zepplin), the temperature shouldn't be causing my auxiliary fan to kick in with hot water gurgling around in the radiator.
Thanks
Who knows.
Thanks
