TR2/3/3A Overheating Bad
wizard2265
Was wondering if someone could possibly point me in a direction with my 1959 TR3A. I am a recent owner the prior owner just rebuilt the engine, about 400 miles on it. The radiator looks clean inside. It suddenly started overheating, bad. Once the gauge starts to move it just keeps going until it is pegged. It acts like a bad thermostat. I pulled the stat and checked it and it fully opens by about 185. I put a 160 in and same thing. I can see the stat opening on the gauge. I have a laser thermometer coming so I can check temperatures of the rad and engine. It sounds like something might of clogged up. Has anybody ever heard of an issue with the water pumps on these? I am assuming it is a new one. Any direction would be helpful.
I know I should just take the Radiator to a shop, but it looks like the only way is to pull the front apron, right. I also check the gauge, at worst it is reading a couples of degrees low.
Geo Hahn
You are correct - the apron comes off to remove the radiator.
If this was a real 'rebuild' then there should not be an accumulation of gunk around the cylinders - one common cause of overheating. You can get some idea if there is a gunk build up by seeing if the drain **** on the side of the block runs freely when open.
Every water pump failure I have had either leaked or made noise - but I am sure there are failure modes I have not experienced.
I assume you have the original style 'capillary tube' temp gauge. Those are usually fairly accurate and do not generally lie to extremes. If, by chance, someone has fitted an electric gauge with a sender & wire then that is definitely worth verifying.
Your coolant level should be about a ¼" or so in the bottom of the neck - have you confirmed this and that you are not losing any coolant (can go out the tailpipe in considerable quantity without being too noticeable)?
Fuel mixture and timing can also affect temperature but usually that is a case to 'running too hot' which is different from 'run-away overheating' which sounds more like what you have.
When you say the 'radiator looks clean inside' how are you able to tell? Easy on a late TR4 where you can remove the cap and look at the core -- not so easy to check on a TR3.
There are a lot of tricks & mods people do to improve cooling (living in the desert I have done a few of them) but what you have is a problem that needs fixing and those mods, while useful, are not going to solve this problem.
W
wizard2265
I totally agree with what you are saying. So it comes down to Radiator, or gunk around the cylinders. I am going to check the drain later today. I also agree with the water pump failure. It is usually a bearing/seal problem. I was wondering if there was a problem out there on "knock off" water pumps stripping out the impeller or something. I was in the aftermarket parts business for 30 years and have seen some strange things. I am leaning towards some gunk dislodging and clogging something. This is only from the fact that it happened suddenly, after running fine for a few hundred miles.
Can they motors be cleaned out by simply pulling the head? Or do you have to totally disassemble it.
Thanks John
Geo Hahn
...it happened suddenly, after running fine for a few hundred miles...
Okay, that info changes things a bit. Sounds like something failed. I don't think the cooling system on these is so fussy that something could just dislodge & clog. A sudden change sounds more like the water pump or thermostat to me.
...Can they motors be cleaned out by simply pulling the head? Or do you have to totally disassemble it...
I cleaned mine using a brass tube attached to a Shop Vac to do a sort of liposuction of the water jackets with the head off. Most of what I sucked out was around #4. Years later when I rebuilt the engine those areas were pretty clean. So yeah, some good can be done with just the head off but it all depends how things are in there.
TR3driver
Great Pumpkin - R.I.P
Does that mean you can see that it stops rising for awhile when the thermostat opens? That seems different to me than "Just keeps going".
Is the cardboard air deflector in place? Early 3A didn't have them, but they are definitely a recommended retrofit. But the main point is that it hasn't slipped and fallen in front of the radiator.
Check the fan belt; the lower generator mount often comes apart which can let the belt slip. Also check the groove in the water pump pulley to see if the belt has polished the bottom of the groove. If so, the belt may have worn until it bottoms in the groove, which allows it to slip no matter how tight it is.
Hook up a timing light and check that the ignition advance is working. The front pulley should have a hole that marks TDC when it lines up with the pointer on the timing cover; but sometimes the pulley gets assembled wrong. At idle, the hole should be around 1/4" from the pointer when viewed under the light. Rev the engine up slowly and let it back down, the mark should move smoothly in response. Only a rough check of course, but worth doing. If the mark doesn't move, or starts jumping around at any point, the distributor needs rebuilt.
Although not common, it is possible for the WP to fail. It's easy enough to remove to check.
I've heard of people getting the radiator out without pulling the apron, but pulling the cylinder head sounds like more trouble than it's worth to me. I've always just taken the apron off; which isn't as bad as it seems as long as it's been off recently. A 7/16" GearWrench with an offset head makes the job go easier.
Unfortunately, the radiator is often the problem; and may not be obviously bad. The original radiator in my previous 59 TR3A apparently developed corrosion in the joints between the tubes and fins, so it just had lousy thermal efficiency even though the tubes were open and clear. I fought with it for a long time before finally pulling the apron and having the radiator recored. All my cooling problems vanished like magic (of course by then I had tried several improvements).
Fast forward 10 or 12 years; I removed that radiator from the wreck (along with the electric fan), had a radiator shop check it out, and installed them both in my current TR3. Which promptly overheated worse than it had with the original radiator and mechanical fan! Eventually, when I insisted that the radiator shop rod it out (even though they said it flowed fine, twice); they discovered that the tubes were coated inside with "mud", probably a mixture of rust flakes and stop-leak. (I always had a problem with the upper tank cracking around the extension.)
Once again, a recore made all the problems vanish. With the electic fan and a few other upgrades, the needle rises to the 185 mark and stays between the center and the edge of the '5' where the fan comes on.
W
wizard2265
Yes the cardboard deflector is in place. This was a sudden problem. Would a timing/advance problem make it overheat this bad? I did just change to a Pertronix dizzy. He had what looked like a $80 Knock off in there. I have the original and was going to have it rebuilt next winter. I am going to check everything you guys said and if I Don't find anything throw the other Dizzy in just because it is so easy to do. I did have the Pertronix advanced quite a bit, but I brought it back to 4 BTDC and the problem didn't change. When the stat opens it goes down a touch before continuing up.
I am really grad I joined this group you guys are great
W
wizard2265
If I end up condemning the Rad. It looks to be in good shape from the outside but could be original (has starter crank hole). Would you guys recommend a aluminium or just a recore.
W
wizard2265
That is what I get for not checking the basics first. The belt used to be tight (snug), now it is loose enough to slip and the pulley is flopping around on the water pump. I think I found my issue. I will report back after I fix it. Thanks for your help. I thought I noticed that the amp gauge was not reading a good charge like it was before. I am really going to have to get used to driving an old car. Lesson learned pay attention to your gauges.
Geo Hahn
...The belt used to be tight (snug), now it is loose enough to slip and the pulley is flopping around on the water pump...
That is good news (all things considered). You may want to read the current thread on water pumps before choosing one.
IMO the belt does not have to be real tight (when all else is good) - I leave mine a little bit loose as the wide belt works well and some looseness is less stressful on the parts.
TexasKnucklehead
Agree.
But also I found that a 160 thermostat is too low. The coolant doesn't have enough time in the radiator on a hot day to cool down, so once the thermostat opens, it never has a chance to close. The 160 t-stat made my car overheat worse than with a 190 t-stat.
Did your over heating start immediately after installing the Petronix? I would make sure your timing is set properly as it also effects the temperature your engine runs.
I still have the crank starter hole in mine and the car doesn't over heat before I do -and it gets hot here in Houston.
Something didn't suddenly start happening without a cause.
DavidApp
I have been trying to find a good belt size for my TR3. It has an alternator and a new water pump/pulley assembly from TRF. I notice that all 3 pulleys are slightly different widths. They are in line.
The best fit I found was the TR24379 from Oreilly's.
I tried the TR28386 which is 39 1/4" x 0.775" That was too short because the new water pump pulley is a bit narrower than the old one.
The TR24379 is 38 1/2" x 0.656"
The TR24400 is 40 5/8" x 0.656" which was too long. It may have been OK with the new pulley but I did not want to push my luck at Oreillys returning yet another belt.
David
Geo Hahn
...It may have been OK with the new pulley but I did not want to push my luck at Oreillys returning yet another belt...
I guess I'm on pretty good terms with my local O'Reillys as they let me take home 3 belts to see which one would fit best, then return the two that I didn't need.
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating 1957 TR-3 Triumph 13
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
P MGB MGB overheating with a squealing noise from the engine MG 11
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
Webb TR6 Overheating TR6 Triumph 13
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
Webb TR6 Overheating TR6 Triumph 6
J '65 Sprite Overheating Spridgets 16
S overheating Spridgets 3
7 Randomly overheating Toyota Other Cars 7
