TR4/4A TR4A overheating issue
gubba
Hi gang.. just got back from ATDI Penticton and I have a question. On the way there I had a terrible pinging going up hill. So I retarded the timing. The pinging was almost gone. On the way home the engine was overheating a little bit ( temp gage always in the middle.. but had risen to 3/4 up ) and the weather was cool. My question is would too lean of a fuel mixture cause this problem with the timing being retarded? TIA
TR3driver
Great Pumpkin - R.I.P
Mixture too lean can sure make it run hot. And running hot will increase the tendency to ping (although my opinion, the timing should not allow pinging even if the engine is slightly overheated and working up a hill).
Late timing can also increase the tendency to overheat (lower efficiency means more heat generated for the same power output).
KVH
I am blessed with two TR4As. One never gets hot; the other overheats at any summer stop light. I've never been able to tell what the difference is between timing settings, mixture, etc. I do both the same way. Frankly, I'm ready for a new radiator on the one.
TR3driver
Very possibly the right answer. I've been through that twice now, once with my previous TR3A and then again with the current TR3. Nothing obviously wrong with the radiator either time; in fact this last time I took it to the radiator shop and they pronounced it "fine". (I made the mistake of asking them to do "whatever it needed".) But the third (or was it 4th) time I took it back, I told the manager specifically that I wanted it rodded and boiled. When they went to rod it out, they couldn't get the rods through the tubes! Apparently, none of the tubes were totally blocked, but they all had enough "mud" coating the inside to block the transfer of heat. Anyway, a new core made all my overheating problems disappear.
The first radiator was still the original type core design, where the fins run more or less straight across and the tubes go through holes in the fins. With it, apparently the tubes were no longer in good thermal contact with the fins, so even rodding it out did not show the problem. But again, a new core made all the problems disappear. The difference with it was really dramatic, I went from having the gauge climb slowly at freeway speeds even at 70F to staying cool even at 115F.
Of course there were a lot of other little improvements made along the way, trying to solve the problem, which I didn't bother to undo later. But the new core was clearly the right fix.
alanjohnturner
Its not really hot anywhere in the UK but we get quite a lot of guys with overheating on 4/4As.
We mess around with timing and mixture and water-pumps of course.
But often it turns out that sediment has built up around the wet-liners
A symptom is that you can remove the block-drain-tap and nothing comes out.
Much of our water supply here has high hardness because of extraction from wells in chalk. Maybe this is why.
Anyway, if all else fails investigate water circulation in the block.
Although its a bit of work, removing the liners and then the sediment is quite straightfoward.
KVH TR4/4A OverHeating TR4A Triumph 7
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
