Still trying to figure this overheating thing out.
regularman
After adding the extra cooling and going for a drive the car ran nice and cool, but the temp climbed when I cut it off and left it for the night. yesterday my electric fan came and I bought an adjustable temp switch and a new thermostat for the car. when I removed the gooseneck for the thermostat, pressure blew out. After being not run for a day there was still pressure in the system? Should it not have cooled down and drew coolant back in and filled the system? I am going to pull the radiator out this evening to install the electric fan as a pusher and still have the option of putting my yellow plastic fan back on if more cooling is needed. Not enough room on the front for the electric fan and at the same time I will check the radiator. My dad has taken them apart and checked them before. If it looks to far gone then I will just buy a new one and quit screwing around. I have my other old one and might rip it part too and see if either are worth fooling with. The thermostat that was in there says made in england on it so it is probably the original. It has 74 on it so I guess that means 165 degrees F and the new one I bought is a 160 degree. Whew.
Atrus
Kim - any chance that you could still be having some headgasket issues? Can't a blown gasket cause massive overheating?
Other than that, I'd say that the thermostat could be bad...sounds like a bad case of heat soak if it climbs when off, but is OK when running. That's the reason some guys run drilled thermostats. It allows the coolant to flow still even when the T-stat is partially or fully closed. Temp probe is near the T-stat though, so I'd assume they should work synonmouosly - if temp looks high, thermo should be open.
I say replace that T-stat, it's cheap and easy!
jlaird
I would say put the thermostat in a pot of water on the stove and see what temp it opens and leave it on awile at that temp and see if it stays open.
OK, I'll bite. Why wouldn't the temperature increase after the engine is shut off? This seems normal to me.
tony barnhill
Great Pumpkin - R.I.P
While you have the radiator out (& before you do anymore mods), backflush the engine & replace the thermostat.
regularman
regularman
Seems normal to me Trevor but what does not is the fact that is seems to push the water out when it does this and continue to hold pressure rather than cool off and form a vaccum and pull the coolant back into the system from the recovery tank like it is supposed to do.
regularman
regularman
Got a new T-stat to put in. I could hook up a garen hose to the head and squirt water through it the other direction and see if anything comes out.
tosoutherncars
Anyone tried the 'trick' of filling the rad (or water passages in the block) with cheap cola, and letting it sit for the night? I hear all sorts of scary things get bubbled loose... but I've been a little hesitant to try it.
tony barnhill
Were it me, I'd backflush through a freeze plug fitting....they make a kit for that.
bugimike
Kim, what kind of condition is the radiator cap in? A bad one, or one with the wrong pressure rating could also cause some of the problems you describe!
regularman
regularman
I tested it and it checked ok. I bought this fairly expensive pressure tester for cooling systems back when the wifes car kept losing coolant and I could not find out where. It has adapters for testing the caps too. It is a 16 pound cap and held about 15 pounds for 30 min, so I guess that is good enough. I would go buy one of them If I thought it would help.
tweety
Re: Still trying to figure this overheating thing
I have a 1979 1500cc midget. I have had very similar problems.... I'm about 70% sure that it's a blown head gasket. The car overheated dramatically and burned off coolant... Milky oil etc. Luckily there was no indication of problems on the spark plugs.
I used some of the K&L head gasket sealer stuff (the old school stuff in the can, not the expensive fancy stuff in the green bottle) and it solved the problem for about six months. I did it again a few weeks ago and it's holding. I need to make it another year or so before I pull out the engine and trany and rebuild.
the key to this product is that you have to get all of the old coolant out of the whole system which pretty much means you have to do a really really really good flushing of the cooling system. I used the Prestone flush stuff and then ran water through the system. I then filled the system with water and drove it for a mile or two, drained and repeated. Squeaky clean inside.
My car also gets hotter when turned off, I believe that this is normal. The only thing I wonder about in your case the pressure buildup. My gut tells me a good flushing is in order.
tony barnhill
16lbs cap? Isn't that too high?
zimmy
how many pack of Mentos do u use with that? :wink:
on another note.....should i fill my overflow tank,
or do i run it empty?
startech47
We need a picture of the radiator cap. There are different styles. The cap has to have a vacuum vent valve and it has to have 2 seals, one at the bottom of the filler neck and one at the top of the filler neck, in order for it to pull coolant back into the radiator when it cools down.
2091351
7 pound system as I remember.
Steve
regularman
regularman
Removed the radiator this evening. Sweated the end off of it and found that the cores don't look too bad. The metal is oxidized but none of that corrosion like you see in prestone commercials. Will put it back together tomorrow after installing the pusher electric fan. Still don't see the big problem. Will also go back with the new 160 degree T stat.
regularman
regularman
I think I might have found the problem. Put the end back on the radiator and pressure checked it on the floor by rigging up some hoses and I found several tiny leaks on both of the tank ends. You can't even see these holes, they don't leak fast and I don't think I would have seen them in the car. The pressure bleeds off really slow, I don't know if I would have caught this on my pressure gauge. Time for a new radiator. I think these tiny holes were slowly letting the water out when hot until it boiled. layed down on the side with air on that side they were easy to find, but with water or antifreeze on them they would have only weeped a tiny amount and on a hot radiator would have evaporated before being seen. Now, who has the best price on a new radiator??
texas_bugeye
Make sure you get a new cap and insure its the correct one it makes a HUGE differance. Make sure the primary seal sits proud enough to seal correctly.
The one I got from Moss was wrong! I thought it was 4Lbs?
Nelson Warranty still good Spridgets 3
B Does anyone still make or sell a quality condenser? Austin Healey 14
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
sparkydave Odd discovery, but still ran OK Spridgets 1
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
RAC68 Directionals, Still a Pain Austin Healey 25
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
steveg Steering rebuild followup - still issues Austin Healey 29
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
K For Sale TR3 grille....not perfect but still useable. Triumph Classifieds 2
C elusive amswersHi Mine is a 66 BJ8. I have 2 questions that up till now I still canno Austin Healey 2
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
GTP1960 General Tech Still in business? Triumph 3
KVH General Tech Still on the Body Work Triumph 6
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
KVH General TR Still Losing Oil Triumph 5
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
BJ8Healeys The scammers are still at it Austin Healey 3
I Quantum Mechanics Ltd still in business? Spridgets 7
CZ_Dave MGB I'm still around MG 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
M Backfiring through carbs still Austin Healey 17
wangdango This BN2 still around? Austin Healey 6
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
R And Still Cooler in Florida Austin Healey 3
mgedit TR2/3/3A Still Overheating ... Triumph 22
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
bigbadbluetr6 TR6 TR-6 still not running right Triumph 31
G MGB STILL working on clutch slave MG 37
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
rjc157 I Donald were still alive Austin Healey 15
RAC68 Still being Surprised Austin Healey 7
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
P T-Series Does my Mark II TD still exist? MG 3
mrv8q They're still out there..... Austin Healey 26
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
KVH TR4/4A TR4A--still won't start Triumph 16
G MGB Still working on front suspesion MG 9
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
dougie Still Time for Christmas Austin Healey 2
jlaird Still here Spridgets 5
X Royal Enfield Bullet, still in production British Motorbikes 4
Frank C. How many Healeys are still on the road? Austin Healey 10
