I finally gto the tr-3 running however the engine is running hot, the prior owner had the rad recored and the crank hole removed and said it ran cool, the car sat for 12 years and I backflushed the system which did not help, I then removed the thermastat and boiled it to see if it opened, it did, but right around 100 C, I took out the thermastat and filled the system with water, when I run the engine it will run at a little over 70 c until I increase RPMs then it will go over to 100C, I put a thermometer in the filler neck and the temp read 80C, so far that is all I have done to the cooling system. Does anyone have any ideas?
Thanks,
captainde
Thanks,
captainde
