MGB MGB overheating with a squealing noise from the engine
Pete L.
Folks,
I'm having a good bit of difficulty with overheating with my '79 MGB. The car has a NEW THERMOSTAT, a NEW TEMP GAUGE SENDING UNIT, NEW FAN BELT properly tightened I believe, recent hoses (2 yrs.) recent coolant change ( -10 ).
Two weeks ago the car started running hot after a short ride of about twenty miles at about 50-60 MPH. No steam, no fluids leaking from anywhere and no smell of antifreeze. The needle on the gauge was up to the leading edge of the red stripe on the hot end of the gauge face.
Thinking it was possibly a faulty gauge or sending unit I changed the sending unit, additionally I changed (today) the thermostat (195%) and filled up the coolant levels.
I then took the car out this and the needle was pinned to the hot end of the gauge and there was an intermittent squealing noise from under the hood. I pulled over, opened up the hood and again no evident signs of overheating EXCEPT that the lower radiator hose seemed SWOLLEN ?
Any help you folks could provide would be greatly appreciated.
Thank you,
Pete L.
JPSmit
Pete, welcome, I am going to suggest that it is time for a new water pump - the pump binding or seized would account for the squealing. and, the lack of circulation the heat.
Platinum
Thirded.
...and back flush the rad at the same time.
P
Pete L.
Gentlemen,
Thank you very much for the help, looks as though a new water pump will be ordered shortly AND I'll back flush the radiator as well...
Pete L.
P
Pete L.
Folks,
After a new radiator, water pump, electric fan sending unit, temp gauge sending unit, thermostat, and lower radiator hose, as well as new antifreeze the car runs fairly cool while in motion...sitting still for a few minutes sends the needle to the "H" !!! I've got to work on cooling the car at idle ???
MustangSix
Member
Overheating at idle indicates a lack of airflow. Are your fans coming on? Check all the wiring and the switch. Also, it's possible to wire these fans to run in reverse, so make sure you have not inadvertently wired them backwards. They should blow toward the radiator with the curved face of the blades facing the rad.
P
Pete L.
MustangSix,
They are indeed running in the correct direction, it seems as though the condition is improving. Even though we're in the middle of a heat wave the car is not warming up enough at a red light to start the fans...not a clue ?
My next move will involve replacing the thermostat housing with an earlier unit, rerouting the upper radiator hose and putting a 12 inch fan on the front of the water pump. This set-up also requires a fan shroud. I've seen this modification a number of times both with and without the front pusher fans and it seems to work well.
David_DuBois
Have you checked the actual temperature of the engine with a no contact thermometer? How about the voltage stabilizer for the fuel and temperature gauge? is it operating correctly, finally what about the temperature sensor in the head - is it operating correctly?
Cheers
JPSmit
MustangSix,
are the fans coming on at all? what temp is that thermal switch set at?
Platinum
A good source for different thermal switches and suchlike is Summit Racing. If you can't find a way to MacGyver the fan trigger point with what they have on offer, you ain't gonna find it at all.
P
Pete L.
Folks,
All seems well now that the weather is cooling off. Had a 200 mile drive last Saturday and the car behaved well...
P MGB overheating 63 mgb solved :] MG 10
P MGB 63 MGB Overheating Help!! MG 18
G MGB overheating MGB MG 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
