MGB 63 MGB Overheating Help!!
Philsmgb
Complete rebuild on the vehicle new radiator new thermostat.
Car overheats very quickly anyone have any suggestions what may be going on. I did notice rust in the new coolant..
jessebogan
If it overheats quickly, I would suspect the thermostat. Is the top radiator hose hot when the car is hot? Is the rad getting hot? What temperature thermostat did you install? It is easy to check a tstat with a pot of water on the stove, a candy thermometer, and a piece of wire to hang the thermostat on. See that it opens at all, and if so what temp does it start to open, and what temp it is fully open.
P
Philsmgb
seems as though the radiator stays cool yet the block is getting very very hot. Tested the them and it works as it should. When Idling it takes a while to get hot with a load gets very very hot in about three to four miles
Deleted member 3577
Yipes......
I have never heard of an air bubble forming in MG engine.
I'd just throw in a blanking sleeve and try it again. (Moss #434-135)
Might be a good time to borrow/buy one of those nifty little infrared-laser gun thingies. (you'll love it)
(The head gasket is on there correctly....Right?)
(does it start fine......ie.not too lean)
P
Philsmgb
Head gasket should be on fine runs great till it gets hot then it starts to cut out and run pretty rough. I pulled the therm and tried to run it without and it still gets very hot. Necer really understood what the blanking plate was for:}
David_DuBois
Phil - If the radiator is not getting hot along with the engne, then something is stopping the flow of coolant throughthe radiator. Did sombody leave a shop rag in one of the radiator ports? don't rool your eyes, that has happened all too often, someone will stuff a rag into one of the ports to keep junk out of it and then forget and leave it in there. What about your water pump, is the impeller perhaps not turning with the shaft? Good luck - Dave
Deleted member 3577
I am getting pretty darn curious now......
I take it you are still "running in" the engine?
jlaird
I agree, it surely sounds like water is not circulating through the radiator. Think I would first remove the therostat and see if that changes things. I mean blanking plate or no blanking plate remove it for a test.
Steve P.
Hummmm...since the engine was just rebuilt, is there a
chance that you left a rag inside? Don't laugh, I've found rags in two engines. Both were wrapped up in the water pump.
I know when I have an engine apart I'll plug all open
holes with rags to keep crud out.
If thats not it, I'd suggest using a flushing compound
to flush the whole cooling system including the radiator.
I'll be doing the same thing on my MGB-GT this week.
jlaird
Guess you could always remove the radiator hose from the pump and crank it and see if water is pumping. Stand back.
maynard
The first thing I would do at this point is a compression test. You said the car overheats quickly, but din't give a time. Is it five minutes or fifteen? A bad head gasket could cause rapid overheating.
If the test comes out OK, try running it without the thermostat. If the stat is defective or installed backwards, you will have overheating.
Check the hoses when the car is running. Does the lower hose collapse when the engine is reved?
PAUL161
If the engine is hot and the rad is cool then there is a restriction in the cooling system. Take all the hoses off and check for a blockage. If you don't find one, then pull the pump and check for blockage in there. Make sure the impeller is tight on the shaft. Is the thermostat new? Check it in a pan of hot water to see if it opens. /ubbthreads/images/graemlins/cheers.gif PJ
Guinn
If it were mine I would first see if water was being pumped TO the radiator, by pulling the upper hose off and running the engine.
If no water or very little is pumped, check the pump. If the pump is good, try to find that rag or whatever is limiting the flow, maybe the thermostat, as the problem would be in the engine.
If you get a good flow TO the radiator, I would check the condition of the hoses. One might be totally collapsed.
If the hoses are good I would consider pulling the radiator and having it cleaned and pressure checked.
Do the easy and cheap things first!
Guinn
jlaird
/ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/thumbsup.gif
tony barnhill
Great Pumpkin - R.I.P
[ QUOTE ]
[/ QUOTE ]
Did they flush the engine & head thoroughly after doing the machine work?
If no machine work was done prior to the rebuild, did you back flush the engine?
[ QUOTE ]
[/ QUOTE ]
The later ones will develop them - that's why you 'burp' them at the bolt on the thermostat cover.
P MGB MGB overheating with a squealing noise from the engine MG 11
P MGB overheating 63 mgb solved :] MG 10
G MGB overheating MGB MG 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
