Overheating after shut down & recommendation on thermostat
PeterB
My 63BJ7 temperature is great while running both parked and moving. My problem seems tobe after the can is run and shut off. Then the temp climbs and pops the filler cap and out comes the antifreeze. Also I was wondering what people’s opinions were between original type sleeved thermostats or the newer replacement style.
Thanks,
Pete
TimK
Leave about a 1 inch space (underfill) between coolant and bottom of radiator cap seal surface. Are you using a 1" neck 7lb. cap? -- which you should be. I'm using the sleeved thermostat--works for me.
steveg
Thanks,
Pete
Peter,
There has been a lot of discussion about thermostats and overflow handling. You can search old threads by entering "thermostat" in the search field on the Healey Forum home page.
John Turney
The temperature usually climbs when the car is shut down. That's because the water pump is no longer pumping, and heat removal is reduced drastically. The temperature bulb (connected to the temperature gauge) is at the hottest part of the cooling system, so as heat continues to dissipate from the cylinders and head into the coolant, and coolant circulation is now only provided by the change in density as it cools in the radiator, temperature at the hottest point will rise for a while and then cool down.
As for dumping coolant, Tim is correct. Either leave about an inch in the radiator for expansion or add a coolant recovery bottle.
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
W TR2/3/3A Overheating Bad Triumph 12
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating 1957 TR-3 Triumph 13
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
P MGB MGB overheating with a squealing noise from the engine MG 11
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
Webb TR6 Overheating TR6 Triumph 13
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
Webb TR6 Overheating TR6 Triumph 6
J '65 Sprite Overheating Spridgets 16
S overheating Spridgets 3
7 Randomly overheating Toyota Other Cars 7
