Oil for rear axle?
Michael Oritt
Steve--
I do not pretend to understand the technical difference between GL4 and GL5 oils but do know that differentials place tremendous loads upon lubricants which is why you will see words such as "Extreme Pressure" etc. in differential oil names, etc. I'm sure someone else will chime in but since there is no yellow metal in your diff there is no reason NOT to use a GL5 oil which is designed for differentials, not transmissions. The 80/90 refers to viscosity, not the oil molecules' resistance to shearing forces, and that--"High Pressure" or "Extreme Pressure" tolerance is what you are after.
A Rear Axle Oil Seal Austin Healey 4
B How often should you change the rear rear axle oil Austin Healey 9
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
6 Rear Axle Oil Seals Spridgets 4
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R correct rear axle oil Austin Healey 1
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
Atrus Rear axle - oil type & quantity? Spridgets 3
AUSMHLY Rear Axle oil Austin Healey 1
B Rear Axle oil breather Austin Healey 6
danielnorton Oil leak from rear wheel/axle Spridgets 17
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
Wana Rear axle oil plugs Austin Healey 15
D MG Midget 1275 rear oil seal. Spridgets 0
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
JFS TR6 Rear Oil Seal? Triumph 1
J TR4/4A Oil leak from rear of motor. Triumph 28
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
J Rear Oil Seal Kit - Spring Austin Healey 9
D Oil Leak at rear of oil pan Spridgets 11
drooartz Rear wheel hub oil seal Spridgets 6
AUSMHLY Oil in rear carb Austin Healey 33
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
1 TR6 oil for rear shocks Triumph 5
R transmission and rear end oil Austin Healey 2
B Rear Wheel Bearing Oil Seal Spridgets 7
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
F More oil leaking...rear seal? Triumph 3
D Oil On Rear wheels MG 6
M Rear Oil Leak Spridgets 5
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
rjc157 moss rear crank oil seal Austin Healey 4
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
