Rear axle oil seal
PeterB
I notice a little spot of oil under where the drive shaft meets the rear axle. I ordered a new seal thinking the old one may be leaking. This is my first time replacing something like this so I have a stupid question. Do I pack any type of grease on the seal or does it just go in dry and refill the rear axle with the recomended oil?
Thanks,
Pete
ALWAYS lubricate a lip-type oil seal upon assembly. Simple grease, or the lube that it will be holding back is sufficient, though I always use Parker O-ring lube whenever I'm installing rubber touching metal.
bighealeysource
Bronze
Hey Pete,
Plus make sure you torque the large nut down per specs or you will get more leakage. You will need to stabilize the flange as you tighten down the nut so a good way is to build a stabilizing bar that bolts to two of the holes on the flange and when you go to torque it down, the bar makes contact with the garage floor and will not allow the flange to move therefore allowing you to tighten the nut properly. I used a piece of steel angle iron, believe 1 inch or 1.5 inches on the side as if you get it too big, can't get to the nut with your socket. Believe the works manual has a good description on how to change the old seal on the rear end.
Regards,
Mike
Any good 80W-90 or 85W-90 gear lube will do--StaLube sells it by the gallon, you'll need about 3.5qts IIRC--though I prefer Redline 75W-90 synthetic. You can go with a heavier (140) gear lube, but I don't think it's necessary. Put some thread sealant on the plugs.
Also, be mindful of the proper positioning of the seal. There is a bevel on the driveshaft end of the third member--the seal should be positioned on the inner edge of that bevel (not too far in). Check the yoke where the seal rides and make sure there isn't a wear groove (shouldn't be, but check). If there's a groove you might be able to clean it up with emery cloth or position the seal just slightly inward (but not much). If it's a bad groove you may need to replace the yoke.
A Rear Axle Oil Seal Austin Healey 4
warwick-steve Oil for rear axle? Austin Healey 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
6 Rear Axle Oil Seals Spridgets 4
A Rear Axle Oil Seal Spridgets 2
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R correct rear axle oil Austin Healey 1
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
Atrus Rear axle - oil type & quantity? Spridgets 3
AUSMHLY Rear Axle oil Austin Healey 1
B Rear Axle oil breather Austin Healey 6
danielnorton Oil leak from rear wheel/axle Spridgets 17
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
Wana Rear axle oil plugs Austin Healey 15
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
