Rear Axle Restoration
robolab
Hello friends,
at the moment I have the rear axle of my BJ8 on the workbench and want to check its condition. The half-axles are already removed.
On my TR3 I had the Differential completely restored, ie. replacement of all bearings and re-adjustment including inspection of the teeth-meshing with marking paint.
Now I am not sure if everything is always necessary. In addition, I cannot get the service tool 18G191B which is required for the exact positioning of the pinion. Or are there other ways to check and adjust . Which parts are most subject to wear.
I am grateful for all comments.
Gerd
John Turney
When I did mine, I replaced the seals and wheel bearings. I left the differential alone, except for changing the oil. Unless it's making noise, I would leave it alone.
Unless they're making "crunchy" sounds, I would leave the pinion bearings and carrier bearings alone. IF the parts are available again__they weren't last time I checked__one of the areas that you can restore to good effect, are to replace the four (4) thrust washers within the carrier for the "spider" gears (these are cupped) and the pair of gears that the axle shafts are inserted into.
As an example, (in the old days...) EVERY TIME I'd buy another MGB, I would replace those four (4) thrust washers and the pin the spiders ride on. It would remove a substantial amount of back-lash from the driveline. I started doing this after having one of the spiders break (on impact...) leaving you with goes innas, but no goes outas!
Put a nice coat of paint on the housing, in you're so inclined (I prefer leaving the aluminum carrier section bare) and do the wheel seals__bearings if it needs them, though they too are quite robust__and call it a day.
Healey Nut
If it doesnt have it already I would spring for the 3.54 ratio gear set instead of the 3.9 .it makes the gearbox much more suited to highway driving , lowers rpm at cruise by about 1000rpm .
Not difficult to do with some basic tools , dial indicator and some engineers blue .
If it already has the 3.54 ratio in it then if if its quiet leave it be .
If it doesnt have it already I would spring for the 3.54 ratio gear set instead of the 3.9 .it makes the gearbox much more suited to highway driving , lowers rpm at cruise by about 1000rpm ....
Agree wholeheartedly; over a few hours at highway speeds it reduces fatigue appreciably. Also makes second gear more usable and makes first gear occasionally usable. Does cut acceleration a bit, though. You'd need a ratio adapter or speedo mods.
R
robolab
I have checked the spare parts availability for rear axle parts at various suppliers. I am surprised that delivery is very poor. Bearings are usually available, but shims are only available in very few dimensions. Is this just a temporary delivery bottleneck, or does that mean the need is missing and rear axles are rarely restored?
R
robolab
I dismantled the differential. All gears and bearings are in good condition. After cleaning all parts I measured the backlash. It is 0.0102 inches. Stamped on the ring gear is 0.007. Is the deviation tolerable, or should the backlash be adjusted?
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
