TR2/3/3A The rear axle "tube" seal replacement.
karls59tr
Bronze
I need to replace this seal. Diff oil leakage not grease. I understand that by undoing the the 6 bolts at the back I can withdraw the hub and the shaft together. How do I determine if I should install a speedy sleeve or just replace the seal? Who sells the specific speedy sleeve I would need? Any additional advice before I tackle this. Thanks in advance.
TR3driver
Great Pumpkin - R.I.P
Take a look at the sealing surface once you get it apart. Chances are good that it will be fine, since there shouldn't be any dirt in there.
If you do need a sleeve, you'll probably have to look it up by size and see where you can find it. I've got a NAPA store that can order any of them; but the other NAPA can only get some (by a different maker), so obviously it varies.
Sorry, I don't recall the size offhand. But you're going to have to get it apart to see if you need one, and it's easy enough to measure when you do.
TR3driver
but probably worth checking the float when done.
I consider it a requirement. But don't forget, both sides have to be assembled before you can check it.
KVH
I just did all this, and made my own tool to pull those seals out. But, I don't recall seeing anything there raising an issue of a speedy sleeve. Where would that go? I have one for the adapter at the differential pinion, but not on the axle shafts.
TR3driver
Maybe I don't understand the question? The lip of the seal rides on the shaft and can wear the surface. A worn or damaged surface may not seal even with a new lip.
Here's one from the scrap pile, that would definitely need a sleeve to be usable. (The photo doesn't show it well, but the area to the right of the rust pits is extremely rough, almost like a fingernail file.)
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
K TR2/3/3A Rear axle hub removal? Triumph 8
catfood BN1 Rear Axle drain plug. Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
bugedd Rear axle bump stop Spridgets 7
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
