KVH
I removed one axle with the hub still on it. I'm inclined to just put it back in after installing a new axle seal. I was about to do the same on the other side of the car, but with the axle still I'm noticing that while spinning the hub flange plate there's a distinct clicking sound. Not screeching, or rusty or sticky, but click, click, as if from the bearing. So, guesswork as it may be, am I hearing something normal from the axle and hub, or is clicking a tell tale sign of a bad bearing? I suppose it might also just be something fallen in the small crack between hub and flange.
