TR2/3/3A Rear axle hub removal?
karls59tr
Bronze
I need to replace the seals in the rear hubs. What can be used to remove the hub instead of the special tool mentioned in the manual?
TomMull
A google search will come up with a couple of examples of hand made pullers. You might get lucky and get it off with a two point puller. You can also take the axle assembly out and do it on a press. Or take it to a machine shop like I do. Tom
bobhustead
Absent the factory tool (which you can't beg, borrow or steal), you need to take the axle to someone with a big press. There is a thread on this site with the design of a puller that would work, it is not worht the effort for a one off job. HOWEVER, I did mine (59 TR3A) last year and did not have to take off the hubs. Take it apart by the bolts that hold the backing plate, pull out the axle, and take a look.
Bob
TR3TR6
I had the same problem with a seal leaking. After soaking the hub for a few days with PB blaster and WD-40 I tried removing it with a large wheel puller, bent that. I tried hammering and then put it on my press. That didn't work. I thought about taking it to a machine shop but was afraid they would damage it. I found this company in Kansas City that supplied used British car parts that also removed hubs. You could either send your hub to them and they would remove it (you pay shipping both ways) plus the cost of removing it, or you could buy a used one from them with new seals and no exchange and pay the shipping one way plus the cost of the hub. I purchased the hub from them and have had no problems with it. This was a number of years ago. What I learned from trying to remove the hub is that you have to apply even pressure on all four sides of the hub and it takes more then a 12 ton press to do the job. Good luck.
Geo Hahn
I suppose it is worth asking... How do you know you need to replace those?
There is also a seal inside the axle casing which is (in my experience) much more likely to wear and leak. If it fails it allows diff lube (oil) past it and into the hubs. The hub seal, I believe, is made to keep grease in but does not do so well with oil if it gets into the hub.
That axle seal is MUCH easier to deal with than the hub seal (piece of cake vs PITA).
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
B Spitfire advice on rear axle/hub Triumph 4
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
glemon Bent Rear Hub/Axle Triumph 2
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
64rocksprite Rear axle hub - bearings Spridgets 8
G TR6 TR6 Rear Axle and Hub - saga continues Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
A Rear Axle Oil Seal Austin Healey 4
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
warwick-steve Oil for rear axle? Austin Healey 3
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
B How often should you change the rear rear axle oil Austin Healey 9
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
T TR2/3/3A Rear Axle Vent Triumph 12
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
B TR2/3/3A Checking oil in rear axle Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
catfood BN1 Rear Axle drain plug. Austin Healey 7
Don_R TR2/3/3A Rear Axle bearings Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
