Spitfire advice on rear axle/hub
Bruce100
I am pulling the rear axles on my 69 Spitfire to change the U Joints. Have the first one off, didn't take long... What else should I consider while I have it off? The car sat since 1989. I know there is a special tool to pull the hub, so I was thinking twice about that....
dklawson
Since you have it torn apart that far how about new brake shoes, checking and rebuilding/replacing the wheel cylinder, and maybe fitting a set of braided SS brake hoses? The rubber gaiter for the parking brake actuator is probably in need of replacement also. What condition are the shocks in? Also, I always clean and paint parts when I have them off a car.
Trevor Triumph
Maybe you might want to reconsider the bearings. After twenty years of no movement, dried grease and assorted crud could make a mess of it later. The hubs, I believe, must be pulled off with a factory tool, however a friend built a tool for his own use. (Years ago I watched a guy here in Phoenix use a slide hammer- didn't look like fun to me.)
dklawson
Agreed. For all the effort to get the axles off it would be false economy to not do the bearings at this time.
B
Bruce100
I decided to have them rebuilt by Axle Works. Already put new brake hoses/cylinders/shoes. Thank you all for the input and help.
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
Bruce_B Upgraded Rear Axle Advice for '59 BE - Question Spridgets 11
F TR6 Advice on TR6 gearbox and rear axle fluids.., Triumph 7
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
R Bugeye rear wheel advice needed Spridgets 20
B BJ8 Rear Brake Questions/Advice Austin Healey 4
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
B TR2/3/3A Advice on TR3 rear bumper overrider source Triumph 7
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
M Rear bugeye upgrade advice Spridgets 18
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
Barryp Rear shroud removal advice Austin Healey 5
Shinsen774 Replacement Tube Shock Rear-Advice MG 1
spiny rust repair advice - rear chassis bit Spridgets 17
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
