Need advice on fitting rear pillar interior trim....
MGrestorer
My 1960 Austin Mini 850 is about ready for the shows and my last job is to fit the vinyl rear pillar covers. I suspect that I might need to remove or at least lift the rear window rubber to install them and I also cant see how they fit over/under the rear side window latch mount. Any sage advice?
Thanks
Steve
Vespa
Member
Newton Commercial parts? They don't fit. Just tried to do mine. They are wrong in various dimensions and don't have the cut out at the bottom to clear the metal seam at the top of the rear seat. SO frustrating.
-Paul B
1960 Morris Mini Minor
dklawson
Vespa, I seem to remember your post on another board about receiving Mk2 pillar covers for your Mk1.
MGRestorer, you are correct, the rear glass has to come out to install the pillar covers, side windows also. Fitting front and rear window glass to a Mini is different from what you normally do with other cars. The "string method" does not work well and can damage those new pillar covers.
Fit the rubber seal to the body opening and tape it in place. If you are using bulk seal material you need to cut it "long" and make sure the ends butt up against each other. Then fit the glass to the rubber seal. Start by resting the glass into the bottom of the seal. Use a plastic spatula or plastic putty knife to lever the rubber up over the glass while pushing the glass down and in. A little K-Y Jelly will make this easier. Work up each side, then across the top.
When the glass is in, you need to fit the lock strip. Make or buy the tool. Do not use a screwdriver or you are likely to hurt yourself or the new paint. Once again, K-Y Jelly will help you get the lockstrip in. As with the rubber seal, cut the lockstrip long so its ends press firmly against each other. Be sure to fit the finishing clip to the lockstrip before pressing the last bit of lockstrip in place.
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
Cyberpyr8 Spitfire Need advice-estimate on Spitfire rebuild Triumph 6
