Need advice, Should I Wrap the Exhaust Pipes?
hmsevans
Since I have removed my Exhaust pipes,I was thinking of wraping them with off the shelf High Temp Wrap to reduce the foot well heat
Does anybody have any advice and reccomendations on what type?
Also need to replace my Heat shields in the same area,What a good source from replacements?
Mark
Thanks again for all the Great advice.
hmsevans, i bought a full set from moss and its a good one, other outfits also sell them, im planning on making up additional section out of 1/4" "wonder board" in the area where my headers run under the foot well, sorry i have no experience with any type of "heat wrap", im sure others can help.
I do not recommend wrapping your exhaust (assuming tubular headers) with an insulating wrap. A thermal barrier coating, applied inside and outside is a much better solution, and the headers will last A LOT longer.
The wrap may show immediate benefits, but it will soak up water (leading to rust) and will also fatigue the metal by subjecting it to intense heat that it cannot dissapate. Your wrapped pipes will live a much shorter life.
red57
I strongly agree with Randy. I used a header wrap once and ruined a nice set of headers in less than 6 months. When a weld broke I un-wrapped the header and it was a mess, the heat had been so intense it had blistered the mild steel tubing - litterally, large flakes of metal had come off and in places it was tissue paper thin, no strength left. These were Denis Welch mild steel tubular headers - maybe different grades of steel or stainless will take the heat better but without reassurances from the manufacturer, I will not do that again - it was an expensive lesson.
I haven't tried any coatings but from what I have read, it sounds like a good way to go.
Dave Phillips
Bruce Bowker
I used JetHot on my Seven headers. I don't have scientific proof but it sure feels cooler in the footwell. Still warm but not as warm.
Looks nice too.
Bruce
Well, I confess to having wrapped my BJ8's stock downpipes. I got the wrap from J.C. Whitney, along with a high-temp silicone coating that seems to work pretty good. The stuff definitely contains the heat, as the exhaust at the tips is now pistol hot. The under hood temps seem to be lower as well.
I just checked the pipes, the wrap is in good shape and the pipes look and sound solid. Let me say I consider this exhaust system expendable, as it's the remnants of an Ansa with some glasspacks grafted where the Ansa boxes used to be, and I intend to replace it in a year or so. I have about 5K miles on 'Frankenmuffler.'
B
BUNDYRUM
Hello hmsevans,The wrap on your pipes is not a good idea as everyone here has said. I had the downpipes on my BN7 done with a thermal barrier coating over 10 years ago and they still look good and it is somewhat cooler in the engine bay. Or should I say, not as hot sounds right. The coating does cost a lot more but in the long term I feel it does pay off. I started off with new stainless steel pipes also.
Best Regards,
bundyrum.
H
hmsevans
Thanks to all for the feedback,I need to stop over thinking the Job and start driving for fun
Thier will be no Wrap on my Pipes
This is site is priceless
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
Cyberpyr8 Spitfire Need advice-estimate on Spitfire rebuild Triumph 6
