Pulled the Trigger...Now I Need Advice!
mxp01
Gentlemen:
I purchased the 1967 Sprite/trailer combo that was on Ebay recently. My son is buying the trailer for $700, so I'm on the hook for the remainder of the cost.
My intentions on this car are to pull the 1275, the disc brake set up, and the sway bar to put on my 1960 BE. I was wondering, what else should I consider taking off this car? Also, are there instruction/directions on how to begin swapping out the brakes suspension from the '67 to the BE? Also, what about the differential? Any improvements if I switch these?
I will be parting out the what remains of the vehicle when I'm finished in order to offset my investment in the '67. If you are in need of something, PM me with your requests. Finally, I will likely be selling the 1098 (that was put on at some point in the past) off my BE, which happens to be in very, very good working order.
Mike Pennell
tony barnhill
Great Pumpkin - R.I.P
Mike - let's talk...if I can use most everything else to make a 1966 Midget (once I find a VIN), I might be interested...I'd be using a 10CC 1098 engine so that might also be of interest....
tony barnhill
Hey, Trevor, that's not a '63 Midget dash or grille...think its an Austin Healy - same as the one Mike bought.
Thanks though
tony barnhill
OKAY - everytime I try to email somebody on craigslist, its always returned as undeliverable...what am I doing wrong?
RickB
Tony, does the address you are sending to look like this:
sale-909621315@craigslist.org
That's the general format. If you are leaving something out then it won't work and you will get that kind of error.
tony barnhill
That's the address
terriphill
I can never click on the address when dealing with craigs list. I highlight the address, copy it, open my e-mail, click new mail message and paste the craigs list address into the to line. THis seems to work about 80% of the time.
M
mxp01
Tony:
I'll let you know how things progress. We can keep open a steady line of communication. I already have interest in the tub.
My 1098's a good engine, so I'll be posting pics in the future.
Mike Pennell
tony barnhill
That's what I did....there's the answer: Unknown user: sale-907390597@craigslist.org
tony barnhill
Well, I've talked with him - it might just be the Midget I've been looking for.
Well Tony, what type of car is it (what is the VIN)? I was guessing it was a '67 Midget with bits from a Sprite.
tony barnhill
I'm still waiting for an email with the VIN & extra photos....its got MG on the dash & trunk lid but an AH grille...at one time had the long piece of chrome on the hood that AHs didn't.....I'm guessing '65 thru '67.
Its the MkII I've been looking for - maybe!
racingenglishcars
For the BE, the gearbox if you still have the smooth case. The 3,9 diff is really nice with the 1275.
Electric tach.
Later rear brakes are nice but I've heard the parking brake system from the BE doesn't work, so you have to have the parking brake cables too.
Isn't the double gauge the same. It's always nice to have a spare.
Does it have the cross flow radiator? If so it's a good conversion.
The steering rack would be good to have.
Head light buckets are the same, though if not rusted.
Many people (like me too) change over to the later style master cylinders.
Easiest to swap out the entire front suspension since you have it. Everything from the A-arms to the shocks. I would even take the brake hoses if they are any good. (but I'm cheap) I think only the spindles are really different, but I'm probably wrong on that point.
tony barnhill
We were both wrong, Trevor...VIN is GAN3L28109...makes it a MkII built between Mar '64 & Mar '65...I'm guessing closer to Mar '64.
Additional photos he sent me show a real solid car with the most rust on the edgers of the bonnet....all the top stuff is in the trunk as is the tonneau & a correct spare....its the elusive MkII I've been looking for: solid, not chopped up, easy restoration.
I bought it as a 1964 MkII Midget!
jvandyke
Officially it'd be a '65 model year car though right? Built in '64 perhaps but an MKII, therefore not a '64. The 64's would be just like your '63.
drooartz
I did something similar recently, pulling the bits off a '74 Midget for my Bugeye.
https://www.drooartz.com/index.php?page=36
Donn covered it nicely in his post. I took pretty much the entire drivetrain: engine, transmission, driveshaft, rear diff. Also took the front suspension (the rack on the '74 was the later style, but your earlier one should fit the Bugeye so I'd take that too). I took the entire parking brake assembly from the lever in the cabin right to the drum plates. I'm currently working on getting that all to work in the Bugeye. The later brake rods can be made to work (I think) with just a bit of finessing.
Quite a bit on the '67 will fit your Bugeye, so if you've got space, strip it out. Good luck!
tony barnhill
Well, that's what I thought but <span style="text-decoration: underline">Original Sprite & Midget</span> says, <span style="font-style: italic">"BMC and Healey addressed this in March 1964 with the Sprite MkIII (HAN8) and Midget MkII (GAN3)."</span> And in the listing of the various iterations of the car, they say, <span style="font-style: italic">"Sprite MkIII and Midget MkII (1964-1966)"</span>.
<span style="text-decoration: underline">MG Sports Cars</span> says, <span style="font-style: italic">"True modernity came to Midgetdom in 1964 with the Midget Mark II (GAN3)."</span>
So, did the Midget change from MkI to MkII mid-year?
M
mxp01
Drew & Donn:
Thanks for the input. I'll be posting regularly to try to better understand the differences in the 1098/1275 to BE set up. I've noticed immediately there is a difference in radiators. The BE has the original radiator. Is it simply a matter of hooking up the water hoses or is therre more?
Anyway, I got the car home today. It does have rust in the floor boards, but they are still in place. There is also rust in some of the usual locations, but based on the overall condition, the tub is very restorable.
Finally, the VIN is HAN 9U / 76411. The carbs are intact. It has dual wipers.
Mike Pennell
Whitephrog
Mike
I'm still interested in the tub. Photos when you get a chance.
H 67 Barnfind, pulled the trigger Austin Healey 15
Marvin Gruber XK140 OTS - Pulled the trigger Jaguar 29
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
J I pulled the trigger and ordered new floors Triumph 21
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
KVH TR4/4A I Pulled the Rocker Arm Off Triumph 7
KeithN60 pulled motor out of stanly last night! Spridgets 9
PATR8 What I found after I pulled the head from my 8 Triumph 15
drooartz Pulled carbs and intake, need opinion. Spridgets 7
livinginthepast Pulled the radiator after a leak was spotted Spridgets 10
T OK - pulled the calipers off - now what? Triumph 16
T What do you think - good thing I pulled them? Triumph 6
N MGB What came out as I pulled the heater core for MGB MG 7
G Pulled the radiator tonight Triumph 4
Stewart All the pulled muscles were worth it MG 6
zimmy pulled the motor! Spridgets 1
wkilleffer Finally pulled the head... MG 53
Ed_K Steve Byers pulled a rabbit out of the hat for me Austin Healey 1
zimmy pulled motor and tranny pics Spridgets 1
jlaird Hay, who pulled the plug Spridgets 3
zimmy pulled my motor .....with pics :] Spridgets 62
zimmy pulled my motor today! Spridgets 25
beaulieu MGA Just pulled home a barnfind MGA , motor stuck MG 9
Gundy Should I pull the trigger? British Motorbikes 58
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
