Pulled carbs and intake, need opinion.
drooartz
Pulled the carbs and intake last night in my quest to find what I think is an intake/exhaust/vacuum leak. The various carb bits seemed to be sealing okay, but I did notice something on the gasket between the header and the head.
The middle and rear branch seem to be discolored underneath where the header touches (you can see this in the pictures below). The front branch didn't have this discoloration. Is this normal or is this indicative of a leak?
Middle branch:
Rear branch:
Platinum
Without a real good inspection of the gasket, a qualified maybe. It kinda looks like a leak on the middle port.
I'd say clean all surfaces, new Payen I/O gasket, be certain all the studs are tight in the head. Check the face of the tubes to be certain they're all three in the same plane (properly finished concrete floor is good enuff for that).
Thickness of the flanges for both the exhaust and intake where the little "clamps" hold 'em against the head should be the same, too. If not the clamps will exert more force on the thicker of the two. Many a bent stud found here from that issue.
Hap's gonna box me earhole but: on reassembly I suggest you apply a thin film of grease on the gasket. Not like peanut butter, more like tanning oil. It'll smoke for a while on first running but it'll help allow the thing to seat/seal on torquing. Run to temp then check/retourque the nuts.
Hap: I'll be available for the whipping after five PM. :smirk:
It would be neat to see the business end of the headers, but that may be more trouble than it's worth, sometime they machined perfectly flat, sometime they seal on welds, and if the welds are not belt sanded flat, then you could not be getting a good seal. Also there the old deal with flange thickness difference from the intake to the header flanges, if they are not equal, you may need to make up some special half washers if you will to get everything to pull down and tighten equally, if the washer you are using now are cocked when tightened, that could very well be your leak.
Platinum
:iagree:
We've even seen 'em where the weld at the tubing wasn't totally sealed and the resulting leak was between the tube end and the flange. That condition is usually apparent from the outside, tho.
drooartz
drooartz
I've got some time this weekend, so I'll go ahead and pull the headers -- not that big a deal, just a little fiddling to get them out with the engine and steering column in place. I'm already in there, so might as well check everything.
I didn't do anything to the header surface when I installed it the first time, so worth checking now.
I'll check the flange thicknesses again -- they are close but not the same if I remember right.
drooartz
drooartz
Thoughts on a good source for a Payen gasket?
-- never mind, found a set through British Parts NW, it's on the way.
sim
I installed some new headders that I bought from moss.
Could not get them to seal even with 2 gaskets. the head is Aluminum
the solution was copper silicon. Been more than 2 years no leaks
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
H 67 Barnfind, pulled the trigger Austin Healey 15
Marvin Gruber XK140 OTS - Pulled the trigger Jaguar 29
KVH TR4/4A I Pulled the Rocker Arm Off Triumph 7
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
KeithN60 pulled motor out of stanly last night! Spridgets 9
PATR8 What I found after I pulled the head from my 8 Triumph 15
livinginthepast Pulled the radiator after a leak was spotted Spridgets 10
T OK - pulled the calipers off - now what? Triumph 16
T What do you think - good thing I pulled them? Triumph 6
M Pulled the Trigger...Now I Need Advice! Spridgets 20
N MGB What came out as I pulled the heater core for MGB MG 7
G Pulled the radiator tonight Triumph 4
Stewart All the pulled muscles were worth it MG 6
zimmy pulled the motor! Spridgets 1
wkilleffer Finally pulled the head... MG 53
Ed_K Steve Byers pulled a rabbit out of the hat for me Austin Healey 1
J I pulled the trigger and ordered new floors Triumph 21
zimmy pulled motor and tranny pics Spridgets 1
jlaird Hay, who pulled the plug Spridgets 3
zimmy pulled my motor .....with pics :] Spridgets 62
zimmy pulled my motor today! Spridgets 25
beaulieu MGA Just pulled home a barnfind MGA , motor stuck MG 9
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
steveg Healeys with Mikuni Carbs Austin Healey 13
P TR2/3/3A TR3B SU carbs Triumph 10
KVH General Tech Carbs Flooding While Car Sits Triumph 55
K 1966 Austin 1100 carbs? British Motor Corp 1
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
steveg HS vs HD series carbs Austin Healey 2
P For Sale v12 carbs Jaguar Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
steveg TR6 HD6 carbs on TR6? Triumph 16
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
Michael Oritt Leak from carbs Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
D Starting After Carbs Rebuilt Austin Healey 30
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
69MGC MGB Wanted: Pair of 67 or earlier Carbs MG 2
