T-Series Need Advice - MGTF Steel Wheels Need Attention
TR3TomG
The steel wheels on my TF 1500 have dents and dings along the rims that meets the tires. I assume from pot holes. Anyway, they look bad.
Is there a company recommended that can get out the dings and dents? Or, am I waisting my time? If so, is there a (good) place to buy replacement wheels?
Thanks for the advice!
PAUL161
Tom, I think that TD and TF wheels are the same. Don't know if the hub caps are though, but I would think the same also. Look on ebay for a set of good ones. I've seen them from time to time. Bent wheels, depending just how bad, are usually a candidate for the junk pile.
There's a set of 5 on ebay right now! Needs sand blasted and painted, but from the photos, they look in good condition. PJ
https://cgi.ebay.com/ebaymotors/MG-TD-TF-...=item3a5fcc34fb
MG TD / TF (LATE MODEL) DISC WHEELS SET OF 5 (665)
Thinking about it, I'd make an offer. The buy it now price seems a tad high.
Scott_Hower
Tom,
Try the Wheel Collision Center. They're about an hour north of you, near Bath PA. They'll straighten steel wheels for about $45ea. Their specialty is repairing aluminum wheels, but they can do pretty much anything with a wheel, including welding and redrilling bolt patterns. I've been using them for years and have been very satisfied. Ask for a tour of the shop.
www.wheelcollision.com
1.800.292.RIMS
T T-Series Need advice re MGTF rack and pinion removal MG 4
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
D Need Some Advice on My 1967 BJ8 Austin Healey 8
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
Cyberpyr8 Spitfire Need advice-estimate on Spitfire rebuild Triumph 6
