Issue with removing front drums and spindles on BE- Need advice
Jim_Gruber
Working on my BE to disassempble the front end in preparation for conversion to Disc Brakes.
Got the ball joint loose and disconnected. Kingpin nut is off, Wishbone has as much pressure as I can apply and still keep it on the jackstand. Bolt that goes through the Trunnion Pin will move back and forth but will not come out. Metal jacket on the bushing for the trunnion could be rusted to the trunnion bolt I guess is the most likely thing.. I've twisted with a 13/16" socket and it turns and all of the rubber that is visible has fallen off. Trunion bolt freely turns with socket on it. So what's next? Do I need to add some helper bolts on there and disconnect the spring to take pressure off or take the cutting wheel and cut the trunion bolt off. Bolt seems stuck in the shock in spite of no locking bolt in the shock arm and a screwdriver wedging the end of the shock arm apart. But I do think more likely t could be that metal jacket on the bushing is keeping everything from moving apart. Ready to get out the cutting disc but don't want a violent coming apart with car on jack stands. I will be removing all and replacing with Disk assembly off of a '71.
Advice Gentlemen?
Rut
Jim,
First thing is to remove the spring with either long bolt method or jack method (engine in car). After that whatever is rusted together gets a sawzall or angle grinder...I save nothing but the spindles (ebay). Since your car still has drum brakes nothing will be of any use to you...just cut it out and order everything from PeterC.
Rut
Jim_Gruber
Jim_Gruber
I've got everything already Rut. Ok in looking at things again the metal piece of the bushing is definitely fused to the trunnion bolt. I will use long bolt method to remove the spring and then cut the trunnion bolt with Angle grinder and cutting wheel to get it apart. Once the pressure is off the spring and I cut the bolt the rest can be cut apart as needed. Thanks.
nomad
Jim, very little work with a hack saw at the base of the flange washer end will let it come out. That is how I have done it a couple of times. All that is necessary is to cut through the sheet metal and turn it.
Kurt.
Jim_Gruber
Jim_Gruber
I'll try that as well tomorrow. It is the washer holding this up.
TulsaFred
The lower fulcrum pin has a notch in it and retaining pin that had to be removed to get it out. That caused me some problems because I didn't see it under the grime.
I can't remember on the trunnion bolt (upper fulcrum pin), but that also goes through the lever shock arm with a pinch bolt. If you haven't removed the pinch bolt all the way, it may have a notched shoulder too. If so you need to remove the pinch bolt completely from the lever arm, not just loosen it. Just a thought.
Fred
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
T 100 BN2 Possible Ignition Issue Austin Healey 7
B MGA Tach drive issue MG 1
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
J Issue with Reverse Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
B General MG Turn Signal Issue MG 1
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A Brake issue? Triumph 8
M TR6 Alternator Issue for 72 TR6 Triumph 7
A TR6 TR6 Distributor cap issue Triumph 4
EricJNewman MGB Weird Brake issue finally solved. MG 1
B Any issue with cutting this weld on the spring base plates? Spridgets 4
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
C TR2/3/3A Water pump issue Triumph 8
Guido36 Chassis Number Issue Austin Healey 11
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
mch979 1967 MGB GT bonnet issue MG 25
H T-Series Brake Issue MG 5
K TR2/3/3A Steering Issue? Triumph 23
P TR3B Coil Issue? Triumph 7
Lin Excellent Issue of the Marque Magazine Austin Healey 2
R TR6 Is this a starter issue? Triumph 6
M Lighting issue Austin Healey 3
B TR4/4A Thrust washer issue Triumph 11
jfarris Honda Parts Issue? Other Cars 1
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Heat-related carb issue on BN1 Austin Healey 7
M TR6 Starter lagging issue Triumph 2
M TR6 PDWA Issue Triumph 5
R Issue with odometer after repair Austin Healey 1
Michael Oritt Bulb holder issue Austin Healey 5
D TR4/4A rebound stop clearance issue Triumph 13
S BJ8 Overdrive Issue Austin Healey 7
Michael Oritt Brake issue Austin Healey 24
G MGB Starter and fuel issue MG 6
S BJ8 Overdrive issue Austin Healey 10
M Help with 60 Bugeye - major drivetrain issue... Spridgets 78
catfood Looking for suggestions - ignition issue Austin Healey 6
N Electrical issue. FORUM Navigation Questions 2
Lin Another trafficator issue Austin Healey 8
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
glemon General Tech Turn Signal Issue Triumph 12
Michael Oritt Speedometer drive issue Austin Healey 4
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
S TR2/3/3A Electrical Issue Triumph 40
F TR6 Frame Issue Triumph 11
