General Tech Turn Signal Issue
glemon
I tried to post this to a Ford Ranger forum, but I am not to impressed with the level of knowledge and activity I am getting there after more than a week, so will try here.
I have a 97 Ford Ranger, stripper edition, no A/C manual steering and windows. Practically an honorary LBC.
The chassis is pretty rusty and I have developed an issue with the turn signals. They work fine on their own, but if I apply the brakes or turn on park or headlights they blink fast like a bulb is out on the dash indicator lights, and I get a weak flash from all four turn signals and the brake light.
Since they work fine when the lights aren't on I am suspecting a bad ground, probably at the rear, but can't find a ground strap back there, though the factory manual indicates all rear lights go to a common ground. Should I just try to splice one in and see if that fixes things. Any other suggestions. If they didn't work normally without the lights on I might suspect the flasher unit too, but since they work normally (all dash bulbs and external bulbs) when lights are off throwing one on is probably just throwing parts at it(?).
Any suggestion? Thanks, sorry to be the Triumph list, but I have been on a bunch of other forums, you guys are the most knowedgable and helpful hands down.
TR3driver
Great Pumpkin - R.I.P
Could be a bad ground, especially if both sides are wired to the same ground point.
But I'm thinking it might be something along the lines of voltage drop in the wiring, so the flasher gets less voltage when other loads are switched on. If adding ground doesn't help; try a "load insensitive" flasher.
glemon
glemon
Thanks Randall, could a bad flasher make it flash through the turn signals and brake lights? Or are you saying I have have a problem a new flasher will fix?
trrdster2000
Clean the sides of the bulbs with some steel wool and sand the base with some fine sandpaper. That will eliminate the connection with the bulb and socket. If that problem still prosiest and your new switch makes no difference have a look at the hazard switch, put it on and off a few times, they do corridor just setting there doing nothing.
glemon
glemon
Thanks, I had all the rear bulbs out but not the front, super clean in there, slid them in and out to do a quick and dirty clean on the contacts, which on these are wires on the bulbs, and the sockets are blade inserts--thanks for the suggestions. I remember my sidelights on the tr250 doing strange things when the lights were not properly grounded.
DavidApp
You could do a jumper ground wire to see if that fixes the problem. Length of wire with alligator clips connected to the battery ground and the indicator base in the back.
David
Rhodyspit75
Quick check. Find a ground wire at the rear, run a temporary wire from there to the negative post of the battery. Try all the lights. If they work then you need to find the ground strap or make a new one. I had Ford trucks for thirty years and you won’t believe the things that have rusted away.
David beat me typing. If you don’t have any wire lying around you could use a jumper cable.
glemon
glemon
Thanks, the jumper wire was going to be my next step, but it is wet and dripping under the truck now, so I followed Randall's suggestion, the linked flasher from Advance fixed the problem. I still suspect there is a marginal ground issue, I recently replaced a rusted out leaf spring mount and my son and I werebanging and poking on the frame a LOT, and the issue appeared right after that (story here https://oppositelock.kinja.com/me-v...KK0ieMWd4frZksTCZQOETYRBGtNgUuvLl2BMRBIcus52F ) I will address that groundwhen it warms up and dries a little, but glad it works now.
Less than 24 hours on the Triumph forum andI got more posts and helpful advice than the Ranger forum in week.
Great Amount of knowledge here, thanks again Greg
Rhodyspit75
Good to hear. On one of my trucks both the rear spring mounts rusted off. The spring ends were actually wearing holes in the bed floor. When I took it in for inspection my mechanic put it on the lift. The truck went up but the rear wheels stayed on the ground until the shocks caught them.
glemon
glemon
Mine looks like it has already had the rear shackle brackets replaced. The drivetrain feels like it will go forever.
TR3driver
Sorry I'm slow getting back. Just to clarify, I did mean that a flasher (like the one you linked to) would work around the problem. The original flasher is probably not defective, but original flashers are designed to flash funny (too fast or too slow) if they don't see the expected amount of current through the bulbs. This was a safety feature on older cars and trucks (including Triumphs); so you could tell from the driver's seat if you have a burned out bulb. But low voltage to the flasher, or a bad ground at any bulb, or even just very old bulbs (sometimes) can cause the current to be low enough to make it flash funny.
But many replacement flashers are designed without this feature.
So, most likely, you still have something limiting the current through the turn signal bulbs. Since you were banging on the rusty frame, it might well be that the bed is no longer in good electrical contact with the frame, so anything grounded to the bed automatically gets a bad ground.
Or, my other point is that the bad connection doesn't necessarily have to be on the ground side. I've even heard of wires corroding enough inside their insulation to cause this symptom.
glemon
glemon
Thanks Randall, no problem in not getting back, as far as I know you aren't getting paid for this and working weekends. Agreed, still think there is probably an issue, but different specs on the flasher are allowing it to "power through" the issue.
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
B General MG Turn Signal Issue MG 1
S Bizarre turn signal issue Austin Healey 10
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
J TR2/3/3A TR3 turn signal issue Triumph 12
WillR MGB Turn signal ground issue DONE. MG 0
hondo402000 TR6 Turn Signal Issue on 71 TR6 Triumph 4
trbob TR6 TR6 TURN SIGNAL ISSUE Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
