TR2/3/3A Rear turn signal lamp and trim installation
SchuyT
I'm having troubles fitting lens and trim onto the rubber body of the rear turn signals- how does one stretch the rubber enough to fit particularly the trim piece without losing the lens?
sp53
If the lights are new, the fit is an aftermarket flaw with poor material. TRF claims theirs fit now after some problems, but I do not know. I actually cleaned up some old rubber sockets I had, and I got some old one on line and cleaned them. I finally got a complete new set to go together off the car and let that sit and stretch; it is still stretching. The socket was very tight with the rim and light in the housing. Back in the day the rubber was different.
steve
2liter4cyl
Bronze
Not easy to explain. Wrap a string with some overlap around the assy. so it is under the flap you want to pull out. Hold the assy. and one end of the string. Pull the other end, the end you pull should be in front of the other , and the flap will roll out. May take some practice. LeT
DavidApp
Just did that job last night. Blown bulb in the turn indicator.
I got the bottom edge of the glass in the rubber then worked the rubber over the glass with a very small Philips screwdriver and a little help from one if those small 90 degree pointy tools from Harbor Freight. The same for the Chrome ring.
David
S
SchuyT
David
Bingo! I could have managed more easily with a third hand, but your method worked nicely- many thanks- SchuyT
D Problems with left rear turn signal Austin Healey 11
A TR2/3/3A Rear turn signal bulbs Triumph 5
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
B How Free / rear wheels turn - XJS & Coil Question Jaguar 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
