TR2/3/3A Rear turn signal bulbs
Arrow
What is the correct bulb for the rear turn signal on a late TR-3A. Outer lights are running and brake. Small round inners are turn (at least that is how I am going to wire it). I bought new assemblies from Moss but they did not come with bulbs and I discarded my old suff. Thanks. PS-I do NOT want LED.
croz
The turn signal bulb is an 1157 single filament.
You may want to consider LED for brake/running lights, strictly as a safety concern. You will be visible.
I'm just saying ...
SC
TR3driver
Great Pumpkin - R.I.P
Strictly speaking, they should be Lucas 380 bulbs. 1157 will work fine, but draw a bit more power than the originals (26.7 watts instead of 21). 2357 draws just a bit more power than 1157 (28.2 instead of 26.7), but will be some 25% brighter. They don't last as long, though.
You're quite right, the round inner lamps were originally turn signals; the kind of tear drop shaped outers were brake and tail. If I was doing it again, I might add the circuit to make them all function as both brake and turn; but of course that wouldn't be original and would be bound to get you talked about :smile:
A
Arrow
What I found was the 1157 is a two filament bulb. The 1156 is single filament and slightly less wattage which is OK with me since I rarely have any of my old cars out at night. Randall as to talking about my car not being "correct" I left that several alterations ago. I have 3 TR-3s. Two original and then this latest project. Mustang II front end, IDIDIT steering column, Currie four link rear with posi, Chevy small block 350, GM 200-R4 automatic tranny, huge fiberglass rear fenders to accommodate 225/55/16 Goodyear Eagles on wide Dayton wire wheels. BUT from all apprearances it lo0ks like a standard TR-3. Back to the topic of electric it also has a HOTWIRE wiring harness.
TR3driver
Sorry, I misread the question. My bad.
You are quite right, the 1157 (and 2357) are dual filament bulbs, suitable only for the front turn/marker lights and the rear brake/tail lights. 1156 will do for the stock turn signals (assuming someone hasn't changed the sockets to take 2357). Or if you want a bit more light output, 2396.
But you asked for "correct" rather than "what fits" :smile:
PS the 1156 should be exactly the same brightness/wattage (they aren't necessarily the same thing) as the bright filament of the 1157.
PPS, Why not LED, since what you have is no longer a TR3 anyway?
croz
My bad :wink-new:. I just included a spare filament.
BTW I use an LED cluster for running and brake lights.
Very bright and not directional. It's a good thing.
SC
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
D Problems with left rear turn signal Austin Healey 11
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
B How Free / rear wheels turn - XJS & Coil Question Jaguar 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
