TR6 Turn Signal Issue on 71 TR6
hondo402000
Went out for a drive last night and I noticed after driving for 30 minutes when I use the turn signal on it would flash slower and slower at each turn till it would not flash at all, When I got home and in the garage, I turned the lights off, the turn signals worked again, turned the lights on still worked but a little slower. the flasher unit is new, well couple of years old, electronic. Pulled the wires and put them back on, the battery is fairly new, dont think it has anything to do with that, I painted my car last year so everything was removed and all grounds cleaned. Any suggestions?
Hondo
NutmegCT
Thoughts on the signal problem:
- any corrosion in the bulb sockets can affect flasher operation, including whether the bulb has been lit recently (warm) or not (cold).
- any old wiring may change the resistance of the wire itself, which affects flasher speed
- the flasher itself could be failing; try a temp replacement with another similar flasher
- all the bulbs need to be the correct amperage ("watt"), so they "draw" equally. Older bulbs can develop non-standard "draw" of current
I've heard that North Carolina can be humid (!); even a few months of humidity, combined with road dust, can cause connection problems in bulb sockets.
Hope this helps.
Tom
hondo402000
hondo402000
I will confirm that the Battery is good and the Alternator is putting out(hehe)
check all connections and grounds and bulbs and purchase a new flasher unit
Hondo
hondo402000
hondo402000
ok here is the update,, cleaned the connections. what i found was one of the front signals were reverse, parking light on one was bright and the other was dim which tells me the wires were backwards, fixed the issue and looked good
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
B General MG Turn Signal Issue MG 1
glemon General Tech Turn Signal Issue Triumph 12
S Bizarre turn signal issue Austin Healey 10
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
J TR2/3/3A TR3 turn signal issue Triumph 12
WillR MGB Turn signal ground issue DONE. MG 0
trbob TR6 TR6 TURN SIGNAL ISSUE Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
