The previous owner fitted a 4 way hazard warning system to my recently acquired BJ8.
All of a sudden the light on the hazard warning switch has started flashing in sync with the beeper when I indicate a left turn. The right turn doesn't flash the hazard light. Both turn signals and indicator lights flash correctly and the hazard system still does what it's supposed to do.
The system looks rather complicated. The green wire from the B terminal on the flasher unit has been routed to a relay under the dash from which a host of wires go off to the hazard switch and goodness knows where else. Any suggestions as to how to check this out would be welcomed.
Thanks
AJ
Thanks
AJ
