Turn Signal Flasher Problem
MGB922
Member
Was having a problem with slow to no turn signal flasher. Cleaned grounds, checked wiring. The turn signal switch was worn and wouldn't return from the left. Changed it and still slow to no flasher. Found this for the flasher unit. A little overkill wasn't it.
Platinum
Should work fine. NAPA, I presume?
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
6 Turn Signal Flasher Spridgets 8
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
N Turn signal flasher?? Spridgets 8
PAUL161 T-Series Turn Signal Flasher MG 8
KVH TR4/4A Turn Signal Flasher and Perceptions Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
K TR2/3/3A Turn signal flasher stays on? Triumph 3
M Where is the turn signal flasher relay? Austin Healey 7
J AH -Turn Signal Flasher Mystery Austin Healey 22
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
BoneIdle MGB-GT Turn signal flasher location 1974 GT MG 0
Moose33 '71 B turn signal flasher removal MG 7
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
J BJ8 Turn signal help needed. Austin Healey 6
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
