'71 B turn signal flasher removal
Moose33
evening all
here's my silly question of the week:
In order to remove my flasher unit (not hazard) it appears as if it is bolted to an area that is only accessible from the engine compartment by removing the absorption canister and then entering through the panel that the canister sits on.. is this correct?
Thanks!
Nunyas
that's a good question. I've been wanting to change mine but haven't had time to begin to look for it lately...
Banjo
I might be wrong, but I think the turn signal flasher is on the interior of the firewall up behind the glove box. It should just be tucked into a clip. its a small square metal box. unless it's been replaced with a can type. You could varify it's the right one if your turn signals still work at all. You can hear the "click, click" and if you put your finger on it you can feel it too.
Moose33
Moose33
ah. it felt solid when I pulled on it and was afraid that if it too was "stuck" that I'd break it and be in a whole new mess. I can hear the *click*-ing when the left signals are on, but not the right and I believe I have the right unit because if I take off the light green wire it doesn't click anymore when the turn lever is pushed.
on a similar note- the right side comes on and stays on, but when I hit the 4-way switch the right front t/s alternates opposite of the other 3 lights.
Moose33
Moose33
Yep- you were right /ubbthreads/images/graemlins/yesnod.gif . It's the little rectangular box held in place by a crusty, rusty clip. see, these are the little things that aren't in the Haynes manual that I usually end up breaking so that's why I ask ahead of time.
Banjo
There might be somthin' wrong with the signal that's working backwards (like a bad ground). but try the flasher first since you're already there. The power for the turn signals runs through the hazard switch (another brilliant manuver by Lucas) and this can cause some strange problems. If the problem changes when you operate the hazard switch a few times then you can gurantee thats where it is.
Also, the flasher operates using the circuit resistance, so if somthing changes that, like a bulb blows, a socket corrodes, a ground is lost, the flasher won't work properly.
Glad I could help.
Moose33
Moose33
got out the schematic and traced it out, was a little surprised to see how it all goes together.
At some point in time, prior to my ownership, two wires got reversed on the hazard switch block. Kinda of a pain in the arse to have to pull apart the center console to changed two wires around, but it all works the way it is supposed to now. I learn something new every day.
danmas
[ QUOTE ]
[/ QUOTE ]
This is not just a "Lucas" peculiarity, it is MANDATORY! All cars that use the same bulbs for the turn signals and for the hazard flashers (and this includes most cars) do this. Whatever you do, do NOT defeat this function.
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
6 Turn Signal Flasher Spridgets 8
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
N Turn signal flasher?? Spridgets 8
PAUL161 T-Series Turn Signal Flasher MG 8
KVH TR4/4A Turn Signal Flasher and Perceptions Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
K TR2/3/3A Turn signal flasher stays on? Triumph 3
M Where is the turn signal flasher relay? Austin Healey 7
J AH -Turn Signal Flasher Mystery Austin Healey 22
MGB922 Turn Signal Flasher Problem MG 1
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
BoneIdle MGB-GT Turn signal flasher location 1974 GT MG 0
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
J BJ8 Turn signal help needed. Austin Healey 6
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
