Need Some Advice on My 1967 BJ8
dmorris1
Member
Hi Everyone,
I need some advice. I have a 1967 BJ8 with an overhaul motor, which was done a year and half ago. The motor has 2300 miles on since rebuild. I'm getting some condensation on the valve cover cap every time I drive and it is turning into a emulsion on longer drives. I getting white smoke on startup also notice some water dripping out on one the exhaust pipe,but it only last for about 30 seconds.Is this normal? I have no coolant lost in the radiator. What do you recommend I do? My first thought is to re-torque the head bolts. The manual recommend 75, is it okay to do 80 or 85? I guess if that doesn't work I will remove the head and go for there. What do you guys recommend. I hear there is quite a difference in head gaskets is there any recommendations that you would advice in terms of thickness(copper or steel)?
Best,
David
Patrick67BJ8
Hi Everyone,
Best,
David
The dripping water out of the exhaust pipe is more likely "condensation" in the mufflers.
Keoke
Just to be on the safe side check the oil in the sump and make sure it is still clean?
Keoke
Will check the sump, so far nothing on dipstick. What about re-torguing the head bolts to 80 or 85 is that okay to do?
If you follow the manual re-torquing to 80 should be OK,but it may not solve the problem-??
Keoke
Is condensation on the bottom of Valve cap normal after drive or a sign of coolant leakage in the head gasket?
It has to come from someplace and they do fail.
Rebuilt engines may seem to be more susceptible than factory original cars given the broad selection of aftermarket parts today..??
LarryK
Not driving far enough to warm motor sufficiently will produce the moisture and color on oil cap. If not changing oil yearly at the least will let this moisture in the engine. Unless you are loosing coolant and have no oil in radiator, drive it more often and get it warm. Do not just idle, that will wash the rings. make sure you have the right rad cap and thermo and retorque the heads again.
W Need advice on installing new side curtain glass Spridgets 1
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
Bayless Need wheel bearing advice please Spridgets 4
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
M Need Advice On 948 Engine Rebuild Spridgets 7
R Need Advice On Refinishing A Bugeye Hardtop Spridgets 15
M TR5/TR250 Need some advice on TR250 Triumph 22
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Jim_Gruber Issue with removing front drums and spindles on BE- Need advice Spridgets 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B Cylinder Head - Need advice Spridgets 5
drambuie Need advice How to Install a volt gauge properly Austin Healey 16
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
I Need some advice on bugeye conversion Spridgets 8
R TR2/3/3A TR3 Seats - Need advice Triumph 9
A need advice on fuel pump Triumph 12
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
tri_carb_healey need some advice Austin Healey 8
Coyote1 Overider Restoration - need advice Triumph 1
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
T Need exhaust header advice/source for Amos Triumph 49
J need advice renewing front lower A-arm Spridgets 31
W restoring a BN2 - need advice on sheet metal Austin Healey 10
Sprocket Barake drum locked up - need advice Austin Healey 7
R engine trouble, need advice Spridgets 16
B I need some advice/suggestions.... Triumph 10
L Need advice on this 1953 XK120M - HELP Jaguar 7
R smiths guage problem- need advice Austin Healey 4
bobmga62 MGA mga hardtop... need reconditioning advice MG 7
kyreb1862 Need Some Advice MG 2
H Need advice, Should I Wrap the Exhaust Pipes? Austin Healey 7
jackq O/D problem..need advice MG 8
M Pulled the Trigger...Now I Need Advice! Spridgets 20
B T-Series Need advice on a 53 TD MG 2
T Need advice on a 1275 Spridgets 6
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
Cyberpyr8 Spitfire Need advice-estimate on Spitfire rebuild Triumph 6
