Rear shroud removal advice
Barryp
Hi guys,
I'm preparing to remove the rear shroud on the BN4 I'm restoring. Do any of you that have done it have any advice?
Thanks, Barry
Bob60
Member
I've removed rear shrouds from BJ8's. As I recall it was pretty straightforward - nuts and bolts plus a lot of pop rivets that needed to be drilled out.
davidb
I've removed the rear shrouds from my BT7 - I agree with Bob 60. Pretty straightforward. Might be some sealing goo/silicone (to prevent electrolysis)from a previous owner between the shroud and the fender if the shroud was removed before.
Once all the obvious (and perhaps not so obvious...) fasteners are removed, use a 3" wide,stiff putty-knife to break the seal from the flange to the inner structure.
Make absolutely sure that the shroud is broke loose all the way around the perimeter before you do any lifting (assuming the shroud is to be reused) as it can be very easily distorted and/or kinked.
roscoe
If there are areas that have seam sealer or some other form of adhesive that is reluctant to come unstuck, try a heat gun. Heat as much as you are able without scorching the paint and a lot of materials will soften.
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
R Rear Shroud Rivets Austin Healey 6
R Mounting rear shroud rain gutter Austin Healey 14
B BT7 Rear Shroud Austin Healey 2
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
R Rear shroud repair Austin Healey 11
maxwedge5281 two seater rear shroud Austin Healey 15
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
T Help ! Rear shroud measurement Austin Healey 14
5 Rear license plate shroud holes location Austin Healey 4
W BN2 rear shroud holes Austin Healey 2
T Rear Shroud Repair Austin Healey 3
Superwrench Rear shroud sealer Austin Healey 3
Superwrench Healey Rear Shroud Restoration & Tools 0
A who was asking for a bn2 rear shroud? Austin Healey 0
H Rear shroud for 2 seater Austin Healey 10
F BN1 Rear Shroud Rivets Austin Healey 8
R BJ-7-Top frame connected to rear shroud? Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
