Rear shroud sealer
Superwrench
Getting ready to put the rear shroud back on my chassis. What sealer did you guys use around edges to keep out water and stop the corrosion between the steel and aluminum ? thanks, Quick
If the panels are coated inside & out with a good primer (like DP40/401) and then painted with a catalized acrylic enamel, I don't think there's much to worry about with electrolysis.
The rear shroud wraps over the chassis flanges (except at bottom rear) so you don't really need a seam sealer until the fenders are attached (and even then, it will be a pain to deal with the beads/sealer at once).
For all the BMWs, I use a brush-on seam sealer I get from Eastwood. 3M has a similar product, but it's stiffer and doesn't flow on so well__you could probably thin it with solvent, but I just keep buying the Eastwood stuff.
I think if you used a butyl-rubber type strip-caulk, you'd risk really damaging the shrouds if they ever had to be removed (collision repair, etc.). Though it would lend itself to "packing the seams" after final assembly/adjustment, etc.
Superwrench
Superwrench
Thanks Randy, Guess that is right. Shroud was epoxy primed and painted and chassis was powder coated. I will probably be dead and gone until any corrosion would start. Quick
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
R Rear Shroud Rivets Austin Healey 6
R Mounting rear shroud rain gutter Austin Healey 14
B BT7 Rear Shroud Austin Healey 2
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
R Rear shroud repair Austin Healey 11
maxwedge5281 two seater rear shroud Austin Healey 15
B Painting underside of front and rear shroud - Original prep and color? Austin Healey 3
T Help ! Rear shroud measurement Austin Healey 14
5 Rear license plate shroud holes location Austin Healey 4
W BN2 rear shroud holes Austin Healey 2
T Rear Shroud Repair Austin Healey 3
Superwrench Healey Rear Shroud Restoration & Tools 0
A who was asking for a bn2 rear shroud? Austin Healey 0
H Rear shroud for 2 seater Austin Healey 10
Barryp Rear shroud removal advice Austin Healey 5
F BN1 Rear Shroud Rivets Austin Healey 8
R BJ-7-Top frame connected to rear shroud? Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
