Rear axle - oil type & quantity?
Atrus
Don't have my manual with me here at work.
What type and quantity of fluid do I need for the rear axle? It was completely rebuilt, so as it sits it's bone dry.
jlaird
90 wt. one container is fine it, is like a quart or less. Fill till it comes out the filler hole.
Atrus
Atrus
Cool, thanks Jack! Man, the parts store will love me this afternoon!
Oil/filter for Jeep
Oil/filter for G6
Trans Fluid/filter for G6
Gear oil for Jeep (front and rear differentials)
Oil for Healey
Gear Oil for Healey
Brake Fluid for Healey
Brake line for Healey
jlaird
Think its called Hyploid gear oil. Preaty standard stuff.
A Rear Axle Oil Seal Austin Healey 4
warwick-steve Oil for rear axle? Austin Healey 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
6 Rear Axle Oil Seals Spridgets 4
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R correct rear axle oil Austin Healey 1
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
AUSMHLY Rear Axle oil Austin Healey 1
B Rear Axle oil breather Austin Healey 6
danielnorton Oil leak from rear wheel/axle Spridgets 17
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
Wana Rear axle oil plugs Austin Healey 15
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
