Rear Axle oil
AUSMHLY
Hello guys,
I am now driving and enjoying my Healey.
Now it's all about keeping up with the maintenance.
Per my prior post I am currently replacing the transmission oil to Redline MT-90 as recommended here.
Today I will feel where the oil level is in the rear axle.
Being I don't know what oil was put in there by the PO, I am not sure what I should add. Is mixing different brands and weights ok?
It maybe a good time to simply replace it. I will then know what's in there.
What do you guys recommend, and how many quarts?
Thank you,
Roger
Keoke
Hi Roger, Unit holds 3.6 US Pints. I like and use Lucas 85/140 Plus Gear Oil.--Fwiw--Keoke
P.S. Drain it and refill with fresh.
A Rear Axle Oil Seal Austin Healey 4
warwick-steve Oil for rear axle? Austin Healey 3
B How often should you change the rear rear axle oil Austin Healey 9
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
6 Rear Axle Oil Seals Spridgets 4
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
R correct rear axle oil Austin Healey 1
W Rear axle oil seals for BN1 or BN2 Austin Healey 0
Atrus Rear axle - oil type & quantity? Spridgets 3
B Rear Axle oil breather Austin Healey 6
danielnorton Oil leak from rear wheel/axle Spridgets 17
AUSMHLY Rear Axle leaking from oil seal dust cover Austin Healey 58
Wana Rear axle oil plugs Austin Healey 15
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R BJ7 Rear Axle Maintenance Austin Healey 5
W Rear Axle Hub Seal Austin Healey 8
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
drooartz Rebuilding rear axle Spridgets 19
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
J TR6 Differential / Rear Axle Triumph 1
Tr3aguy TR2/3/3A Rear Axle Rebuild Triumph 3
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
BN6_2197 Rear Axle rearing up Austin Healey 12
K Rear Axle Breathers Austin Healey 17
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
S Rear axle - small leak .....? Austin Healey 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
P MGB Noisy Rear Axle / Differential MG 1
R Rear Axle Restoration Austin Healey 6
Lin Rear Axle Hub Nuts Austin Healey 3
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
